Front Speakers Q - JeepForum.com
post #1 of 7 Old 08-17-2013, 09:18 AM Thread Starter
TJEvans
Front Speakers Q
I've been considering replacing my front speakers, but I know that they are a pain to get to.
I was wondering, is it possible to cut out the front "screen" portion of the dash that they are hidden behind, replace them, and somehow reattach the portion that was cut out?
Rather than try to access them from behind, I want to get to them from the front. I theorized that I can pull out my dremel tool, cut the plastic, replace the speakers, then either glue, or screw, or a combination of both, the plastic back on...
Would this work?
TJEvans is offline
post #2 of 7 Old 08-17-2013, 10:12 AM
chefboyardee86
you could do that but it will also be a pain to build some kind of bracket to hold the speaker. it took me half an hour to bring the windshield down and bring the dash down. i tink kicker is selling a template on quadratec to drill trough the speaker grill to take the speaker out.
chefboyardee86 is offline
post #3 of 7 Old 08-17-2013, 10:19 AM
SeanB95YJ
I got tired of the accessability (and poor sound) of the 4x6s I could find... so I just left em there, disconnected them and installed a decent set of 6x9s in the door. I used weatherpac type connectors so if the mood strikes, I can still remove the doors... but in the 4+ years I've had it, I've never removed the lowers for driving.
don't have a detail shot, but here IS a pic that shows the speaker in the door.
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #4 of 7 Old 08-17-2013, 12:21 PM
mykeyb01
Are those after market door panels? I like the idea but a, curious if they will fill on my stock panel?
mykeyb01 is offline
post #5 of 7 Old 08-17-2013, 12:24 PM
metalhead
2011 WK
I have been wondering the same thing. If there was a way to cut that out and mount the speakers a better way so if something happens to them it is easier to replace them.
metalhead is offline
post #6 of 7 Old 08-17-2013, 02:44 PM
roadyrob
1987 YJ Wrangler
Would this work?
first, its not plastic, its steel. guess it would be possible to use a speaker cover after you cut a hole but to me it would look like****.
its really not that bad pulling the dash, just be sure to use a good grade marine speaker like polk.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #7 of 7 Old 08-17-2013, 03:14 PM
SeanB95YJ
as far as I know the panels are stock half door panels that came with the Jeep... mine's a 95, so they may differ slightly from your 88... never really paid attention to others.
just need to get a 6x9 template and play with the positioning on the panel. in addition to obviously cutting the panel, I did have to cut some of the sheetmetal from the door itself, but since it's just hollow in that spot (no lock mechanism and of course no window regulator) it wasn't a big deal to cut out a 6x9 oval in the inner skin.
swap/build thread:
