Front Shackle Reversal - JeepForum.com
post #1 of 14 Old 10-01-2013, 02:02 PM Thread Starter
rollover755
Has anyone done this, reversed the shackles ? Does it work well? Is it worth it ?
rollover755 is offline
post #2 of 14 Old 10-01-2013, 02:26 PM
Lostfedexman
IMO no, it is not worth it. When the springs compress with the shackles on the front, the front axle get's pushed slightly forward helping the tires grip the surface that your trying to climb.
If the shackles were reversed, when the springs compress the axle gets pushed slightly backward which is counter productive. That's my $0.02
[]llllll[]
Colorado Jeep Club Member #4267
Lostfedexman is offline
post #3 of 14 Old 10-01-2013, 02:45 PM
TSEJEEPERS
No I am not running them but from what I have read the Jeep will ride much better with a reverse shackle set up.
Another plus is when wheeling in rocks you would have less tendency to bend a front spring. Since the front of the springs do not have the shackle when you come up to a large rock ,or really anything that your shackle would hit, you would not be pushing the spring back.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #4 of 14 Old 10-01-2013, 08:43 PM
jserna
1987 YJ Wrangler
SR's work great. I have had MORE's SR on my YJ for over 10 years and I have no complaints or issues. I wheel with guys that all types of set ups, and loss of traction due to spring movement is something I have never had any problems with.
jserna is offline
post #5 of 14 Old 10-01-2013, 09:30 PM
GrantYJ
Do you daily drive the Jeep or is it primarily used for wheeling? If it's an off road toy, the reversal would give you a better approach and most likely more effective droop, and a softer ride. On road, they can add to bump steer problems depending on how stiff your springs are.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.” ― Robert M. Pirsig, Zen And The Art Of Motorcycle Maintenance: An Inquiry Into Values
GrantYJ is offline
post #6 of 14 Old 10-02-2013, 04:39 AM
superj
i want one but haven;t gotten one yet but my buddy, (who is the owner of Trucker's World, oldest 4x4 shop in corpus christi texas) had one on his yj back when he had a jeep and he said it made a huge improvement on road.
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #7 of 14 Old 10-02-2013, 06:13 AM
Siva283
It gives a better ride on the road because it lets the axle move back a tiny bit as you hit a bump. Where as with the shackles in front the axle is push forward ever so slightly which amplifies the bumps in the road. Traction loss is negligable. It will not cause enough traction loss to really notice. However there is a reason Jeep put them in the front and that is because they felt it would give better traction. With that said just get a quality set of springs and you wont need it. My BDS springs ride very very nice. I have 3 ruptured disc's in my back and I still ride comfortable. I can put coffee in my cup holder and it even stays in the cup until I drink it.
Ask me how I know...
Siva283 is offline
post #8 of 14 Old 10-02-2013, 08:40 AM Thread Starter
rollover755
good stuff guys.... It is a driver(not daily) and I do take it mudding and in the trails... Right now it has some stiff a$$ 4" springs in it and it ride like a lumber wagon..I just started tearing it apart for the winter to rebuild again, I think will look into less of a lift spring, maybe stock or 2" lift and go SOA to keep my height...
post #9 of 14 Old 10-02-2013, 08:43 AM
Siva283
SOA on stock springs gets you 5.5 inches of lift and you have a whole new set of issues to deal with. Get some quality springs. BDS, OME or RE. It will ride much better require less work and be $1500+ cheaper than a proper SOA.
Siva283 is offline
post #10 of 14 Old 10-02-2013, 10:00 AM
jserna
1987 YJ Wrangler
I drive my jeep all the time street and trail. It is nice to be able to drive 85 down the freeway.
jserna is offline
post #11 of 14 Old 10-02-2013, 10:57 AM
tydp
Yep
I have the Full Traction SRS with BDS springs (2" front 3.5" rear). I drive on road 99.9 % of the time. It take the harshness out of bumps, NO bumpsteer, tracks great. I like it...YMMV. It was well worth it to me. I can let go of the wheel and it goes straight down the road....good luck...
tydp is offline
post #12 of 14 Old 10-02-2013, 11:14 AM
Siva283
I got mine to a little over 100 mph the other day. I then promply **** myself and slowed back down. Jeeps and triple digits do not go together in my book.
What does driving 85 on the freeway have to do with SRS anyway?
Siva283 is offline
post #13 of 14 Old 10-02-2013, 12:11 PM Thread Starter
rollover755
ok, let me give a few more details.... currently I have 4" springs(SUA) w/ 2" extra shackles and i run on 35's with stock axles.... I'm now just starting a axle swap to D44 in front and 9" in rear. I was thinking since I'm going SOA I would go to a stock spring with stock shackle length, that should keep about my same height and give me a better ride, but since I'm going frame off I figured this would be a good time to do the spring reversal IF it is worth it.
post #14 of 14 Old 10-02-2013, 12:59 PM
ssyj94
SRS has a few up and downs I ran the MORE setup for about 7-8years.
Pros
-smooths out the ride on the street
-extends wheelbase 2-3"
-rides better on mild trails
Cons
-you'll need a big money long travel front shaft togo with it
-brake dive thats can be minimized by adjusting ypu shackle angle but is still way worse than stock setup
-on steep ledges creates front wheelhop
-shackle mounts will still break off if hit hard
All in all id skip it.
My build:
ssyj94 is offline
