Front shackle bracket - JeepForum.com
post #1 of 36 Old 02-06-2009, 01:43 PM Thread Starter
superjet86
I just noticed my front drivers side shackle mount has broken off the frame... i have seen the replacements sold that are suppose to be better... but i dont know how to weld. how much do you think a shop would charge to put these on?
http://www.quadratec.com/products/92000_103.htm
thanks
superjet86 is offline
post #2 of 36 Old 02-06-2009, 04:27 PM Thread Starter
superjet86
I dont think it would be too much but just wanted to check if thats the way i want to go.
post #3 of 36 Old 02-06-2009, 04:37 PM
Brandon_YJ
1987 YJ Wrangler
If you grind everything down to clean metal, th where all they have to do is magnet the braket up there and lay a bead... I'd guestimate anywehere between $25 to $40.
Originally Posted by Mean Max View Post
I think I'll keep the YJ. But can I talk you into taking the wife?
DISCLAIMER: I (usually) browse the web using
in a (text only)
. Which means I do not have image viewing support. So if you get confused by my seemingly inability to comment on your pictures, emoticons, etc; now you know why.
If you're still confused
to see how I view the forum.
Brandon_YJ is offline
post #4 of 36 Old 02-06-2009, 05:42 PM Thread Starter
superjet86
what ones do i need to replace the stock? i see 2" and 2.5".... is that referred to lift? i just ant stock size... can you post links of that i need!
Thanks
post #5 of 36 Old 02-06-2009, 05:48 PM
Brandon_YJ
1987 YJ Wrangler
I could go out and measure mine and see... but you coulddo that as well I reckon.
And see my signature for the reason I don't post pics.
in a (text only)
post #6 of 36 Old 02-06-2009, 06:10 PM
RockWoRM
RockWoRM's Avatar
The hangers you posted in your quadtech link are primarily for CJ's and such. You can make them work, but they will require some modification. If you want something more OME, then I would get these...
http://www.currieenterprises.com/ces...ct.aspx?id=998
they worked quite well for me.
not hard to do yourself... this was with my hobart 140, 110v.
WRM
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
post #7 of 36 Old 02-06-2009, 06:30 PM
bigsquat
i believe your springs are 2 1/2 inches wide and thats what their refering to. the cj's are 2"
red 92 yj,4.0,dana 44 rear,xj driveshaft,rubi 4-1 tc,35"tires,smitty built winch,oba, 6" flares,hand throttle,aussie's front and back,posi-lock,6" lift.anti-wrap, hombrew bumpers, rack and sliders,cb,rear shock truss <>< ,MY BUILD:
Two fish swim into a concrete wall. One turns to the other and says 'Dam!'
bigsquat is offline
post #8 of 36 Old 02-06-2009, 07:01 PM Thread Starter
superjet86
technically those are the same are they not? the ones from quad are a bit cheaper....
post #9 of 36 Old 02-06-2009, 07:31 PM
bigsquat
the cheaper ones might interfer with the bumper unless you can modify them
bigsquat is offline
post #10 of 36 Old 02-06-2009, 07:32 PM
RockWoRM
RockWoRM's Avatar
Nope! The CJ style hangers sit flat against the frame. The YJ front bumper uses the torx bolt under the frame to hold it on. So, to use the CJ hanger, even if you get the 2.5 width, it will have to moved "back" or modified if you're still going to use the stock bumper. This will throw off your shackle angles, too. Maybe not a big deal to some, but this is why the YJ hangers are off-set forward and down. The hangers I posted are also stronger chromo's, hence the higher price.
WRM
RockWoRM is offline
post #11 of 36 Old 02-06-2009, 07:36 PM Thread Starter
superjet86
yea i will buy the ones you posted... so basically the flat ones would cover the torx bold holding the bumper on?
post #12 of 36 Old 02-06-2009, 07:56 PM
TSEJEEPERS
Ruff stuff has these too.
http://www.ruffstuffspecialties.com/...ger-p-182.html
They are a little cheaper but you have to weld the DOM to the bracket. They also come with the bushings.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #13 of 36 Old 02-06-2009, 07:58 PM
RockWoRM
RockWoRM's Avatar
It would cover the torx bolt only if you removed it. It has to sit flat. You either have to move the CJ one back or remove the bolt to place it in its proper position. I like my stock bumper and I like chromo's. No brainer for me.
RockWoRM is offline
post #14 of 36 Old 02-06-2009, 08:13 PM Thread Starter
superjet86
I ordered the ones Rockworm has... just hope my shop in town does not charge me an arm and leg to remove the one still on the frame and weld these on... do you think they will charge more than 100$?
post #15 of 36 Old 02-06-2009, 09:40 PM
Exparrot
Exparrot's Avatar
I had the same problem, and I couldn't weld at the time either...
I had a buddy that could weld, but didn't have access to a welder on a weekend.
So, I got the best of both worlds. I bought a Hobart 125EZ welder, paid him a 6-pack to weld the bracket on, and taught myself how to weld. Couple of frame patches and a new front bumper later and I don't know what I did without a welder.
If you have welding buddies, drop a couple hundred on a good (read: not Harbor Frieght, et al.) welder and have them do the job for you. Best thing about it is, once you learn to weld, you'll have to find excuses NOT to get into the garage and burn through some scrap metal!
I got a Jeep, it's lifted and it's got crap bolted to it.
Color by Rattle-Can.
LO Jeep Club #111 [and not proud of it]
Red Jeep Club #MC399
Exparrot is offline
Front Shackle/Bushing bracket hanger dprg644 YJ Wrangler Technical Forum 13 05-02-2009 07:51 PM
Recovery with Warn rear Bumper and Warn Shackle Bracket littlebrother TJ Wrangler Technical Forum 2 03-02-2008 07:06 PM
Front shackle ? learfxr YJ Wrangler Technical Forum 1 06-16-2007 07:58 AM
Front Shackle Mount zolon YJ Wrangler Technical Forum 7 08-03-2005 04:58 PM
Folded front Shackle :( Bigbluejeep YJ Wrangler Technical Forum 17 12-07-2003 07:07 PM
