Front License Plate help - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Front License Plate help
8.8 Swap Kit w/ TRUSS for JeepsROCK BOTTOM prices on LIFT KITS at Rockridge4wd!! WANT TO Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 05-17-2012, 09:48 AM   #1
Hoobah
Hey everyone, I have had my "new" '95 Jeep YJ for a little over three weeks now. Just yesterday I registered my vehicle and got license plates for it and was looking to replace them with the temporary plates. The rear plate installed fine, however, I don't see any way to attach the front license plate.
Any help is greatly appreciated!
Thanks in advance!
Hoobah is offline   Reply With Quote Quick reply to this message
Unread 05-17-2012, 09:51 AM   #2
Gilthanas
the two slots on the passenger side of the bumper are for the front plate. On mine I couldn't get bolts through very easily
Gilthanas is offline   Reply With Quote Quick reply to this message
Unread 05-17-2012, 09:53 AM   #3
Luuca
TYPICAL /F12 HOOLIGAN
Luuca's Avatar
Depending upon which front bumper you have, if any, you may have to get creative. On most, there are slots cut into the bumper. Go to your local Autozone, O'Reiley's etc and get a license plate mounting kit - some screws and plastic inserts - any use them as directed. If you post up a pic of your bumper, it would help us to determine your best course of action.
91 YJ "Alice" 2.5L, AX5, 2.5" OME 36Rs, 1" Shackles, 32" Yoko ATs, 4.10 D30/35 Busted Knuckles
05 LJ Rubicon "Ghost" 4.5" RE, 1.25" BL, 33" Atturo MT, 4.10 D44 F/R Locked
YJ FOR SALE
Luuca is offline   Reply With Quote Quick reply to this message
Unread 05-17-2012, 09:55 AM   #4
Hoobah
Yes, the bumper is stock. To get both sides of the top attached, it seems as if you'd need to remove the bumper to get the inner-most bolt in place.
Unread 05-17-2012, 10:13 AM   #5
Luuca
Luuca's Avatar
Don't get too upset when, after having removed the bumper and all that to mount it with the plastic inserts and screws from the auto parts store, you see it flying in the wind behind you at 70 MPH on the freeway. Mine did. Oh well.
YJ FOR SALE
Unread 05-17-2012, 10:23 AM   #6
grandboost98
grandboost98's Avatar
yeah youre better off keeping it as a spare for when the rear one rips off
72 Chevy Nova-in progress
98 Pontiac Grand Prix GTP-:SOLD:
http://tiny.cc/BRASSBALLSOFFROAD
grandboost98 is offline   Reply With Quote Quick reply to this message
Unread 05-17-2012, 10:42 AM   #7
chico166
I used a telescoping magnectic thingy and put the nut on it, then I carefully slid it in behind the bumper to the slot where I could see the nut threads and then carefully attached the plate with a small bolt. Make sure u get a magnectic thing with a small head because its tight in there
2013 JK Unlimited Gecko Green, 4" Skyjacker lift. Pro-Comp 35" Xterrain tires
chico166 is offline   Reply With Quote Quick reply to this message
Unread 05-17-2012, 12:54 PM   #8
4x4JB
Here's the slots. Mine is in the middle due to the tow bar bracket.
4x4JB is offline   Reply With Quote Quick reply to this message
Unread 05-17-2012, 01:49 PM   #9
Gilthanas
I've seen guys just zip tie the plate to the grill as a temp fix
Unread 05-17-2012, 02:28 PM   #10
Anticanman
Follow me
Anticanman's Avatar
Yep. It's a quick easy fix. If you are dreading the removal of the bumper then just get some self tappers and drill a pilot hole for them to get started. If you do remove the bumper, then I would strongly suggest replacing the bolts with a set of hex head grade 8 models and liberally costing the bolts with antisieze then using a lockwasher before cinching them down.
I didn't think license plates were that difficult to install.
Luck Favours The Prepared
"Whiskey is for drinking, Water is for fighting over" - Mark Twain
Anticanman is offline   Reply With Quote Quick reply to this message
Unread 05-17-2012, 02:59 PM   #11
PeteYJTJ
I also drilled and tapped 2 holes in the center of my shortened stock bumper.
Pete
88YJ:SOA/locked/35s/Superwinch=Wheeling Jeep.
04WJ:4.0/3"+10mm/Superwinch=DD & Expedition Jeep.
PeteYJTJ is offline   Reply With Quote Quick reply to this message
Unread 05-17-2012, 03:28 PM   #12
roadyrob
1987 YJ Wrangler
WOW! 11 posts on how to install a licence plate
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is online now   Reply With Quote Quick reply to this message
Unread 05-17-2012, 04:09 PM   #13
superj
1987 YJ Wrangler
ha ha ha
I don't feel like working on anything, at this time.
superj is offline   Reply With Quote Quick reply to this message
Unread 05-17-2012, 11:03 PM   #14
timatoe
timatoe's Avatar
It's a very technical subject.
timatoe is offline   Reply With Quote Quick reply to this message
Unread 05-18-2012, 09:25 AM   #15
Luuca
Luuca's Avatar
I'm waiting for Que to chime in. Troubleshooting of this magnitude is normally his forte'.
YJ FOR SALE
