Front frame extension - JeepForum.com
post #1 of 46 Old 02-27-2008, 09:12 AM Thread Starter
E_ROCK
Front frame extension / Front stretch
Do you think this would work on the front of a yj if you cut the existing front cross member out of the way?
http://www.pirate4x4.com/forum/attac...hmentid=141805
http://www.pirate4x4.com/forum/attac...hmentid=141806
http://pirate4x4.com/forum/showpost....03&postcount=2
Garage Monkey, Wheeling Junkie
E_ROCK is offline
post #2 of 46 Old 02-27-2008, 12:32 PM
fratis
fratis's Avatar
why? what is the goal in doing this? in your example pictures I'm not clear on why this was done in the first place. usually if you bob the frame or build a new back half it is to tuck the frame rails under the bed of the jeep to allow for suspension options like longer rear shocks run vertical. in the front, the frame rails are already as narrow as possible.
fratis is offline
post #3 of 46 Old 02-27-2008, 12:47 PM Thread Starter
E_ROCK
I want to extend the front wheel base up front 5 to 6". I have shackle reversal up front and would like to keep it. That means I would need to extened the front rails forward to mount my frame side leaf mount. I could extend my front wheel base the same way that doug_1994 or Tomb Raider, with the shackle forward design on the end of a cross memeber. But, my knuckle have been rotated with shackle reversal in mind and I don't know what it will do with my caster.
Why the front and not the rear? Well, I just finished an atlas II install + tummy tuck. The front output of the Atlas is a couple of inches farther forward than the NP231 which would cause me to have to shorten the front driveshaft. Well, I never take the easy road. So instead of shorten the front driveshaft, I said why not push the front axle forward. I have my fenders off right now, so access is easy to the frame. Also, I have made a new hood hoop that needs a frame support. I was going to tie the hood hoop to some new shock hoops, but I didn't what to weld the shock hoops yet because I wanted some more wheel base.
E_ROCK is offline
post #4 of 46 Old 02-27-2008, 04:19 PM
91yjwrangler6
It's kinda pointless to stretch the front frame rails unless your running mud drag races. Those are usually the only jeeps you see that have stretched front frame rails.
91 yj, 4.0, AX15, SOA, 8.8 rear, 4.88 gears, 2.5 inch springs front, m.o.r.e shackle reversal, m.o.r.e shock hoops, 3 inch springs in rear, bilstein 5150's, shock bar, m.o.r.e traction bar, lockers, m.o.r.e high steer, SYE, old school bronco cv shaft, tube fenders, 36 inch tsl's
91yjwrangler6 is offline
post #5 of 46 Old 02-27-2008, 04:20 PM
doug_1994
doug_1994's Avatar
Thats exactly what I plan on doing to my front end. I have my shackle hangers mounted to the front of my bumper, where as I would like to have them below the frame. To run a shorter shackle. I want to keep things as low as possible.
Doug
Wise men speak because they have something to say;
Fools because they have to say something.
Plato
doug_1994 is offline
post #6 of 46 Old 02-27-2008, 04:26 PM Thread Starter
E_ROCK
Doug
Have you been able to find any good pictures of other peoples rigs? I have been web researching for days now and I am not really coming up with anything.
E_ROCK is offline
post #7 of 46 Old 02-27-2008, 04:39 PM
doug_1994
doug_1994's Avatar
No, I haven't seen any pics, but it would be just like the ones you posted.
If I come across any I'll be sure to pass them on to ya.
Doug
Plato
post #8 of 46 Old 02-27-2008, 06:17 PM
1 ton yj
1 ton yj's Avatar
My friend Rob stretched his front about 6" with wagoneer springs. He made new spring buckets and mounted the shackles to the front crossmember tube. He didn't lengthen the frame at all. He estimates it to be around 3" of lift right now with the SOA, it is l-o-w and it works until he breaks a main leaf but that's another story.
107"
1 ton yj is offline
post #9 of 46 Old 03-17-2008, 12:23 PM Thread Starter
E_ROCK
I know this is a very "open ended" question, but how many inches should I stretch the front? I was going to do 6" right now and I still plan on shackle reversal, extending the front frame with a new cross member, and relocated the box foward.
E_ROCK is offline
post #10 of 46 Old 03-19-2008, 03:37 PM
doug_1994
doug_1994's Avatar
I guess it would matter on what size tires you are running.
Mine with 110", and 39.5" tires my belly drags alot.
Thats why I want the flat belly in the worst way.
Plato
post #11 of 46 Old 03-29-2008, 08:16 PM Thread Starter
E_ROCK
I guess I decided on 6". I still plan on running 37" tire this next season.
I made a frame extension for the pass side.
A buddy of mine came up with a good idea of how to cut the driverside sleeve so that we could salvage the captive nuts in the frame and reuse them.
Captive nuts - We cut them out and rewelded them into the sleeve.
I found some 3/8" steel sch 40 pipe nipples that fit a 7/16" bolt great.
I found this when I took my axle apart. Pass side U-joint was about to blow
This is about were we left it. It should be ready to add a cross member/bumper.
E_ROCK is offline
post #12 of 46 Old 03-30-2008, 07:59 AM
northjeep
Jeep parking ONLY
northjeep's Avatar
What is that 3x4 1/4" wall?
-NorthJeep - >> Just Enough Essential Parts
northjeep is offline
post #13 of 46 Old 03-30-2008, 08:30 AM
TSEJEEPERS
What axle is that in your last picture?
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #14 of 46 Old 03-31-2008, 08:22 AM Thread Starter
E_ROCK
It is a low pinion, waggy D44.
E_ROCK is offline
post #15 of 46 Old 04-19-2008, 04:18 PM Thread Starter
E_ROCK
Here is the important side, the steering box side.
The grill gets in the way of the PS box hoses. Both the front of the grill and the engine bay side had to get trimmed.
Passenger side
Side view
Front view
E_ROCK is offline
Rough Country Budget Boost no front shock extension ??Why?? Mike_Motorbike TJ Wrangler Technical Forum 9 12-09-2009 02:56 PM
Windshield Frame Question...Roll bar extension mounting? BumbleBee90 YJ Wrangler Technical Forum 4 07-02-2008 11:11 PM
How long front bump stop extension with OME lift? saxart TJ Wrangler Technical Forum 12 03-08-2008 06:36 PM
TJ Front Bumper Extension (End Caps) PaulW TJ Wrangler Technical Forum 3 09-19-2005 03:26 PM
Writeup for a FREE front brake hose extension pasowicz95yj YJ Wrangler Technical Forum 2 04-14-2004 07:55 PM
