Quantcast Front Exhaust Pipe - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Front Exhaust Pipe
Old 08-08-2003, 09:02 PM   #1
Vetteman
Front Exhaust Pipe
Anyone know why it's so hard to get a replacement OEM front exhaust pipe for a 95 YJ with the 4.0L 6 cylinder? Have a break in my front pipe and cannot seem to locate one from local parts stores let alone one from Chyrsler. Any suggestions where I can locate this pipe?
1998 TJ Wrangler Sahara [COLOR=White]White[/COLOR] 4.0L/5spd/ RE 3.5" SF w/ADJ upper rear control arms/RE Adj Track Bar/RE Monotubes/1" Daystar Body Lift/Teraflex Extreme Short Shaft & CV driveshaft/ Mickey Thompson ATZ 33's on DC 15x10 wheels/4:56 gears w/rear Locker/WARN winch
2007 Atomic Orange[COLOR="DarkOrange"][/COLOR] Corvette Conv 6speed/BillyBoat Quad Bullet Exhaust & Cosmetics....Cruisin' Time!
Vetteman is offline   Reply With Quote
Old 08-08-2003, 09:18 PM   #2
RCHavok797
Are you talking about the pipe that goes from the exhaust manifold to the cat? If so then Banks makes one, atleast they do for my year.
2005 LJ Impact Orange 4.0L Automatic (Tigger) - new ride
1991 YJ Sahara 4.0L Automatic
1978 Dodge Lil Red Express - work in progress
RCHavok797 is offline   Reply With Quote
Old 08-08-2003, 11:40 PM   #3
gtflyer
call banks...they have it!..it is part #51308...bye
gtflyer is offline   Reply With Quote
Old 08-09-2003, 06:26 AM   #4
sfr246
i used to have a 94 YJ and found the only way to get the front extention is to either buy headers or as i was told from crystler you may buy one, but it included the cat converter and will run you about $300
1997 ZJ LIMITED. 5.2 V8.
sfr246 is offline   Reply With Quote
Old 08-09-2003, 09:25 AM   #5
Vetteman
Thanks folks for the replies. Not to be ignore, but does anyone have the address & number for Banks? I can understand the cost being so high if the manifold pipe leading down to the converter is welded at the converter and is included. Big $$$$$!! But "they" should still offer the dumb part!
Glock Forum
