Front end Whine - JeepForum.com
post #1 of 4 Old 04-12-2007, 08:02 PM Thread Starter
ufatbastehd
Front end Whine
I started getting a whine from the front of my rig yesterday.
The whine gets louder the faster I go, I originally thought it was coming from the engine by the alternator side.
But It doesn't happen with the riigs not moving and I rev the engine.
So i guess its axle related.
It's been raining here and can't check my diff fluid level til saturday.
Would low or no diff fluid cause a whine?
ufatbastehd is offline
post #2 of 4 Old 04-12-2007, 08:07 PM
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
Big-n-Broke-YJ's Avatar
yes it would..... and yes it would definatly hurt/ruin your axle.
however, with a stock front axle, the carrier doesn't spin unless you are in 4wd.... IF the vacuum disconnect was stuck engaged, it would spin the carrier though.... if your front driveshaft spins in 2wd, your disconnect is stuck and the whine very well could be coming from your front diff....
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs
Big-n-Broke-YJ is offline
post #3 of 4 Old 04-12-2007, 08:20 PM Thread Starter
ufatbastehd
Thanks I didn't realize the carrier wouldn't turn, guess I'll mark my front DS to see if its turning in 2wd and go from there
post #4 of 4 Old 04-12-2007, 08:47 PM
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
just hop in, put her in 1st and idle down the driveway with your body hanging out the door and look
-Erik <--- usually holds onto the steering wheel with one arm and prays it doesn't fall off
whine in 4 lo jeepgeek2k TJ Wrangler Technical Forum 15 12-19-2009 12:59 AM
Whine? lizard20 TJ Wrangler Technical Forum 1 01-21-2008 07:13 PM
Whine? Deezul TJ Wrangler Technical Forum 9 01-21-2006 02:29 PM
Whine mcastie89 TJ Wrangler Technical Forum 1 09-20-2005 12:52 PM
Whine? nightstalker5.0 YJ Wrangler Technical Forum 16 03-15-2005 01:25 PM
