#1 | |
front end questions
i just put a set of 31's on my 93YJ and when i i drive it about 55- 60 MPH i get a BAD vibration in the front end i thought it was from the tires not being balkanced right so i took them and had em done and watched as they all came 0.00 meaning the balance is good. someone told me it might be my steering stabilzer. How do i check it to see if it's bad? I got under it yesterday and looked at it i did notice a lil fuild on it like it has a bad seal but i would like to know how do i check it to be 100% sure it needs to be replaced?
#2 |
just replace it anyway and upgrade it to a good one
#3 |
Be careful when you replace the stabilizer - when I replaced mine the mounting bolt at the axle snapped off flush with the mount. It was a real PITA to drill out and install a new bolt stud. Maybe soak it in PB Blaster for several days before.
wb2510 Late Jeep Club #3 1994 YJ, 2.5L, 5 speed The rest of the family: 2006 KJ Liberty 2008 JK Wrangler Unlimited X |
#4 |
well got the stablizer changed what a PITA the bolt on the front diff came right out it was the other one that gave me a problem had to cut it off and knock it out with a air hammer. and when i got the old one out i guess it needed to be changed BAD i could push it in and out with NO problem
#5 |
So did that fix the vibes? i have the same situation.
1993 4.0 31's, 7in flares, highflow cat & flowmaster muffler ( all to pass inspection) |
#6 |
yeah it did but the front tires are not the best i have a little vibration still in the front end nothing like before though. so i'm gonna get 2 new tires for the front so that should fix it
#7 |
Jeep parking ONLY
Do you have vibes in the back?
If not, but your back tires on the front. Same vibration? Then it's your front end components, ie: Ball joints, End links, wheel bearings, or suspension bushings etc.
-NorthJeep - >> Just Enough Essential Parts RED Jeep Club member - YJ Club - 258's Unite |
#8 |
Shifter extension?
Okay, stupid question...the used beat up YJ I bought has a shifter only about a foot off the floor. It has a 2.5 RE lift, as well as a 1 3/4" shackle lift. Is this due to the tranny not being raised? I don't know how long the shifters were to begin with, so I don't know. I did by a 3" shifter extension, but it doesn't thread down all the way and the shift nob doesn't fit. It seems eveything on this thing is hacked together, and I am just trying to make it a bit more driver friendly.
#9 |
sorry about that! how do i start a new topic? i am new to this!
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
