Front end noise - JeepForum.com
post #1 of 3 Old 08-08-2011, 11:36 AM Thread Starter
94YJ4L
Front end noise
So, recently, while turning, I heard a popping noise in the ffront end.
I have recently changed out the hub on the driver's side. Also, I changed the tre's and drag link ends. I think I might've tightened one down too much. Would this cause the noise or is it the trac bar (bracket slightly loose)?
94YJ4L is offline
post #2 of 3 Old 08-08-2011, 12:56 PM
pasinbuy
Sounds like your track bar. Remove it and throw it away. Along with the rear track bar. Do a track bar search and you will find that those that know say to remove it and throw it away.
pasinbuy is offline
post #3 of 3 Old 08-08-2011, 02:18 PM
Getdirtyoffroad
Toss it! Don't need it!
Getdirtyoffroad.com
Getdirtyoffroad is offline
Popping noise front front end jeepinohio YJ Wrangler Technical Forum 0 03-28-2010 10:52 AM
Front end noise, 4-wd noise, now nothing! 98SaharaUSMC TJ Wrangler Technical Forum 8 01-08-2010 03:52 PM
new front end noise ( vid ) - front diff?? alecmcmahon TJ Wrangler Technical Forum 6 12-13-2008 07:21 PM
Front end noise....? BIGWILL78 YJ Wrangler Technical Forum 9 10-16-2007 11:42 AM
HELP: Front End Noise, shortly after I did front brakes lagunarich TJ Wrangler Technical Forum 7 12-16-2003 10:20 PM
