Front driveshaft u-joints - JeepForum.com
post #1 of 5 Old 04-06-2010, 03:04 PM Thread Starter
Beerlover
2005 WK
I'm in the process of replacing front DS u-joints. After I get the caps seated in the yoke far enough to get the retaining clips in, it seems like they are sort of tight and bound up feeling. They don't turn really smoothly. Will this loosen up with use after it's reinstalled? When I put the caps on to test fit before putting everything back into the yoke, it's nice and free and smooth. Just wondering if anyone else has noticed this or maybe I'm doing something wrong. I've replaced axle u-joints before and didn't notice the tight feeling.
93 YJ, 4.0, Auto, 4" RC, 33's
Beerlover is offline
post #2 of 5 Old 04-06-2010, 03:16 PM
provinT13
Are they greased up and the correct size?
2 Hands Working Do More Than 1000 Hands Praying
provinT13 is offline
post #3 of 5 Old 04-06-2010, 03:18 PM Thread Starter
Beerlover
2005 WK
Yep, correct size and fresh grease. It seems like the caps have to press down on the end of the ujoint ears a little in order to make room to get the clip into the slot. if there was a way to tap the cap back out from the inside, it seems like it would be perfect. I guess I'll just put it all back in and see what happens.
post #4 of 5 Old 04-06-2010, 05:32 PM
notmyj
Don't run them if they are tight. They will over heat and self destruct. With the DS yoke on a hard surface like a vice, anvil, even a brick, strike the DS ears with a hammer. Spin it 180*, and strike the other side. Don't use a sledge, just a regular hammer with a sharp blow.
Besure you do not hit the u joint, or have the joint in contact with any thing. Try turning the joint after each hit and you will feel everything loosen up. Repeat until it is smooth, using lighter taps of the hammer as it loosens up.
If it has tracks, tires or tits, its gonna cause a problem.
"Everytime someone "upgrades" a D35, an angel looses its wings."
"Dizzy" - What SnoopDog would call a Distributor if he was a mechanic. I cringe every time I hear this moronic term
Originally Posted by Warren Zevon
Send lawyers, guns and money. The **** has hit the fan...
92, 4.0, AW4, 8.8, D30, 15x10, 37's, SOA etc, etc
92, 2.5, 30, 8.8, 4.88, Locked, Winch, 15x8, 35's, 3.5" (RIP)
notmyj is offline
post #5 of 5 Old 04-07-2010, 10:50 AM Thread Starter
Beerlover
2005 WK
Thanks - that sounds like good advice and I'll give it a try.
i need help (Front driveshaft u-joints) boomerjeep TJ Wrangler Technical Forum 35 06-21-2010 07:28 PM
U-Joints front driveshaft? doubleup TJ Wrangler Technical Forum 6 03-10-2008 08:31 PM
Front driveshaft U-Joints, Spicer? 90SaharaJeep TJ Wrangler Technical Forum 0 01-21-2008 12:02 PM
Front Driveshaft U-joints TellyDSP YJ Wrangler Technical Forum 1 05-13-2006 02:23 PM
Front driveshaft u-joints?? jeeplover27 YJ Wrangler Technical Forum 9 10-31-2005 09:09 AM
