Front driveshaft not spinning - JeepForum.com
post #1 of 3 Old 02-27-2013, 12:30 PM Thread Starter
saler
I recently installed a 4x4 posi-lok in my yj, thinking it was the issue with my 4x4. Since installing it, I have yet to have my 4x4 working. I thought it may be the shift fork, but had a buddy look under, and saw that when the cable was engaged, the shaft spun. However, when only engaging the T-case, there was no movement.
The t-case still goes in low range and shifts through fine, but no power is going to the front driveshaft. Also, the t-case is fairly new (about a year and a half old) and I can't think of what issue may be. Any advice is appreciated!!
saler is offline
post #2 of 3 Old 02-27-2013, 12:32 PM
johnny27030
Something is wrong with the transfer case. Broke chain maybe?
johnny27030 is offline
post #3 of 3 Old 02-27-2013, 07:08 PM
915kingwrangler
http://www.jeep4x4center.com/jeep-tr...-231-parts.htm
Check this link out it will let you know more about your t case. Now the chain is hard to snap, along the years it will get some slack which in turn will cause it to pop horribly everytime you engage the t case, but thats not the case here. This problem with the t case not engaging is most likely due to the fact that the range fork is worn out and might not make it engage, you will have to open the t case in order to fix this, its not that hard to fix, I consider prying open the case the hardest thing, but other than that its pretty simple, search around here to see if theres a writeup on t case rebuild.
*** I AM THE PUNISHMENT OF GOD..IF YOU HAD NOT COMMITTED GREAT SINS, GOD WOULD NOT HAVE SENT A PUNISHMENT LIKE ME UPON YOU..***GENGHIS KHAN
915kingwrangler is offline
front driveshaft , transfer case
