front drive shaft vibes after balancing - Page 2 - JeepForum.com
post #16 of 22 Old 11-22-2011, 08:08 AM
mighty4banger
Originally Posted by kojak70 View Post
Mighty4banger....you r the man! If I am ever near morrow ohio I will buy u a cold half dozen of your favorite mixture of barley and hops. The vibration is still there at 65 and 70 but it is considerably less noticable. I can drive it like this and still have 4wheel drive. This will give me some time to decide before i drop the coin on the new ds. Thanks again for all the replies. Happy Jeepin!
glad 2 help ya... nothing like a free fix!
I don't daily drive my jeep so the flip was a better option than dropping the coin...
95 YJ 2.5L 5 speed, 4.88's, Aussie Locker D30, 35" Mud Rovers, Herculined tub, TKH rear bumper, Ford 8.8, JB Conv. SYE, Sylvania Silver Stars, T-MAX 9K winch, MORE 1" body lift, Turbo City oil pan skid, Rubicon Express 4" lift...
2012 KK Black all stock.
mighty4banger is offline
post #17 of 22 Old 11-23-2011, 10:38 PM Thread Starter
kojak70
Alright alright...200 dollars later...nice 3"dia. brand new shiny balanced ds and it vibes just like the unbalanced one. Granted it is not a TW ds but... I removed this new shaft and drove around in 4hi just to see if mmaybe the tcase had something to do with it. With shaft out no vibes in 4hi. Could the piniongear be loose enough to vibrate at speed and not leak or make noise at low speed? I dont know what to do other than have the front end pulled apart and see if something looks wrong?
kojak70 is offline
post #18 of 22 Old 11-24-2011, 07:30 AM
Louie4
"You pass butter"
Louie4's Avatar
That sucks. Have you tried grabbing the yokes on the axle and t-case and trying to move them? Did you try swapping the driveshaft around so the slip joint is at the t-case and vice versa?
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #19 of 22 Old 11-24-2011, 09:12 AM Thread Starter
kojak70
yes the yokes feel very tight. I did flip the ds around and it helped but the vibe is still present. Maybe the front yoke (which is brand new) is out of center just enough to cause the vibe at hwy speed? I think i may swap yokes and see before i tear into the diff. I will let yall know what happens
kojak70 is offline
post #20 of 22 Old 11-24-2011, 01:10 PM
Alfons
Originally Posted by bikerdude View Post
Are your u-joint angles on the front shaft the same front and rear? If they are different from your lift, (I don't hnow what you have for a lift) you could be getting a vibration that you wouldn't have felt before because of having the CAD.
I think that this is the key to the problem. When you changed your axle configuration, you've made it so that your drive shaft turns even with 4wd deselected at the transfer case, so if the jeep has been lifted and the front and rear joint angles are different, you'll get a vibration as the drive shaft rotates - EVEN IF the shaft is perfectly balanced. The vibration is a result of how single cardan joints operate.
For a front axle that has different joint angles, the only real solution is to put a double cardan at each end and then balance the shaft. I use the spicer double cardan joints from an XJ front shaft to make YJ front shafts, they're cheap & they work well in this application. This twin double cardan joint configuration leaves you the capability to set your caster without worrying about joint angles.
Alfons is offline
post #21 of 22 Old 11-24-2011, 01:33 PM
scifone
Learns the hard way
scifone's Avatar
When you have your driveshaft balanced are they balancing it with the yoke still attached? Buddy of mine couldn't get rid of his vibes until he got his driveshaft balanced with the yoke on it.
scifone is offline
post #22 of 22 Old 11-25-2011, 12:30 AM Thread Starter
kojak70
I must agree with Abraham...Lincoln that is...."The problem with internet quotes is the verification of validity"... or something to that affect. The ds was not balanced with the yoke attached. I am starting to regret selectable hubs vs. selectable lockers inn yjs. I must remember ancient chinese secret..."Patiance Grasshopper...Rome was not built in a day"
kojak70 is offline
Balancing Ring on Drive Shaft? GoldenEagle06 TJ Wrangler Technical Forum 0 12-06-2010 10:03 PM
Front drive shaft vibes blueyj TJ Wrangler Technical Forum 2 09-28-2010 08:44 PM
Regeared to 4.88. Now need drive shaft balancing? CB3 TJ Wrangler Technical Forum 35 09-20-2008 04:37 PM
Drive shaft balancing Supertau TJ Wrangler Technical Forum 0 08-08-2008 08:38 PM
Post lift vibes- Front drive shaft? Cobo TJ Wrangler Technical Forum 5 01-31-2006 02:58 PM
