front drive shaft vibes after balancing - JeepForum.com
post #1 of 22 Old 11-20-2011, 10:56 AM Thread Starter
kojak70
I have recently had my d30 regeared to 4.88, 1pc. tj shaft, chromemoly and spartan zip locker. Everything works awesome offroad. I love not worrying about the cad working correctly. This is my dd and at highway speeds (55-75) i have an annoying pulsating vibe from front( i think). It continues if i coast without power. I had my front ds balanced and it continues to do the same thing. If i remove the front ds everything is peachy. no vibes. it has no play in slip yoke, new joints, yokes on axel and tcase are new and torqued to spec. I also replaced motormounts and right side unit bearing. trans mount looks good and is new. I have read that the diameter of ds is a problem after certain rpm ranges ( over 2000 ). Now for my question..... will a 300 dollar new 2" ds solve my vibes, iyho, or did i waste my money on a selectable front locker and am going to have to install lockout hubs to solve this? I appreciate in advance all your advice. p.s I am running 35" tires
kojak70 is offline
post #2 of 22 Old 11-20-2011, 11:19 AM
raynmaker
I also have this pulsating vibe. would like to know the solution.
Warning: This poster has infinite knowledge of useless information and redneck tendencies. Use info at your own discretion. :wave:
raynmaker is offline
post #3 of 22 Old 11-20-2011, 11:30 AM
jeepnbrett
I would contact the company that balanced the drive shaft and voice your concerns. Let them know the problem goes away when you remove the shaft and ask them to check the shaft again.
Brett
4.0, AT, 3.5 Fabtech, 1" SRS, 1" BL, 35x13.50x15 Toyo MT's, HP30, TJ shafts, Lockrite, 8.8, Power Trax No Slip, 4.11's, Warn bumpers, W8274, SYE, and a bunch of other stuff....
jeepnbrett is offline
post #4 of 22 Old 11-20-2011, 11:48 AM
bikerdude
1987 YJ Wrangler
Are your u-joint angles on the front shaft the same front and rear? If they are different from your lift, (I don't hnow what you have for a lift) you could be getting a vibration that you wouldn't have felt before because of having the CAD.
bikerdude is offline
post #5 of 22 Old 11-20-2011, 04:09 PM
mighty4banger
Try flipping the front drive shaft around. (Put the slip yoke closer to the transfer case.)
It helped mine. 4.88's, Aussie and solid front shaft here as well.
95 YJ 2.5L 5 speed, 4.88's, Aussie Locker D30, 35" Mud Rovers, Herculined tub, TKH rear bumper, Ford 8.8, JB Conv. SYE, Sylvania Silver Stars, T-MAX 9K winch, MORE 1" body lift, Turbo City oil pan skid, Rubicon Express 4" lift...
2012 KK Black all stock.
mighty4banger is offline
post #6 of 22 Old 11-20-2011, 05:12 PM Thread Starter
kojak70
I have a 4" rc with 1" booms and a 2" body lift. The pinion angle looks flat and staight. My sons 94 jeep has the 2" diameter front ds. My ds is the smaller 1" diameter. I was going to use his ds and see if it helped but the slip yoke is well worn so i didnt think it would help. I do not see any weights on my ds. The shop did replace the splines because mine were sloppy. I did not deal directly with the balancer so who knows. (friend of a cousins friend) I am going to go and flip ends and see if that helps. thanks for all the replies. Happy Jeeping
kojak70 is offline
post #7 of 22 Old 11-20-2011, 05:15 PM
Louie4
"You pass butter"
Louie4's Avatar
I'm having the same issue as you. However when I had my front driveshaft balanced it took most of the vibes out. Well after a while they came back and it's due to the slop in the slip yoke. Mine has a little lateral movement at the slip joint. My plan is to buy a brand new Tom Woods as a stock replacement but it will have longer splines and a thicker tube. I asked the question a while back about this same thing and one reply was from someone who bought a replacement TW and no vibes.
That's what I plan to do at least.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is online now
post #8 of 22 Old 11-20-2011, 05:19 PM
tevans59
1979 CJ7
Back in the 80's I had a cj that a broke bell housing, well after replacement my jeep would vibrate like crazy about 35 mph, so took it back down and recheck it all even the little copper bushing in the crank, well that did not work........ well the problem was the drive shaft yolks were not line up when we put it back together, some how the shaft came apart during the first drop of everything.
tevans59 is offline
post #9 of 22 Old 11-20-2011, 06:37 PM
MLJeeper
MLJeeper's Avatar
I had this same problem. Turned out my slip joint was just used up, to much slop. Bought a new heavy duty TW drive shaft and never looked back.
Edit: Slip joint....not yoke
Your limited slip differential sucks.
Any video of the sound?
MLJeeper is offline
post #10 of 22 Old 11-20-2011, 07:13 PM
Louie4
"You pass butter"
Louie4's Avatar
Originally Posted by MLJeeper View Post
I had this same problem. Turned out my slip yoke was just used up, to much slop. Bought a new heavy duty TW drive shaft and never looked back.
I believe this is the fellow who told me about his TW front driveshaft.
I plan on keeping my stock driveshaft as a trail spare.
Lou
YJOTM July 2012
YJOTM February 2014
post #11 of 22 Old 11-20-2011, 08:37 PM
jeepnbrett
Ditto on the Tom Woods shaft. I had to go with the longer spline version. With a 1 piece passenger axle shaft and a lock-right I have no vibration issues.
Brett
post #12 of 22 Old 11-21-2011, 07:00 AM
mighty4banger
FYI - My slip joint is sloppy and the flip has helped...
post #13 of 22 Old 11-21-2011, 06:24 PM Thread Starter
kojak70
Mighty4banger....you r the man! If I am ever near morrow ohio I will buy u a cold half dozen of your favorite mixture of barley and hops. The vibration is still there at 65 and 70 but it is considerably less noticable. I can drive it like this and still have 4wheel drive. This will give me some time to decide before i drop the coin on the new ds. Thanks again for all the replies. Happy Jeepin!
kojak70 is offline
post #14 of 22 Old 11-21-2011, 06:44 PM
MLJeeper
MLJeeper's Avatar
Originally Posted by kojak70 View Post
This will give me some time to decide before i drop the coin on the new ds.:
When your ready give Tom Woods a call. I know you always hear people talking him up like were pimping him or something, but he really does a great job. Customer service is second to none. My heavy duty front shaft was just under 200. They arent that bad without the double cardan.
MLJeeper is offline
post #15 of 22 Old 11-21-2011, 06:47 PM
dillonjm
2013 WK
Agreed. I have owned 3 TW driveshafts on various rigs over the years and none of them have disappointed.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
Balancing Ring on Drive Shaft? GoldenEagle06 TJ Wrangler Technical Forum 0 12-06-2010 10:03 PM
Front drive shaft vibes blueyj TJ Wrangler Technical Forum 2 09-28-2010 08:44 PM
Regeared to 4.88. Now need drive shaft balancing? CB3 TJ Wrangler Technical Forum 35 09-20-2008 04:37 PM
Drive shaft balancing Supertau TJ Wrangler Technical Forum 0 08-08-2008 08:38 PM
Post lift vibes- Front drive shaft? Cobo TJ Wrangler Technical Forum 5 01-31-2006 02:58 PM
