front drive shaft spinning in 2wd - JeepForum.com
post #1 of 4 Old 04-12-2009, 02:45 PM Thread Starter
jeeptim
I have an 87 yj all stock running gear, stock vac actuator and all, when I drive down the road in 2wd my driveshaft spins, but my tc is locked in 2wd. Is this normal?
jeeptim is offline
post #2 of 4 Old 04-12-2009, 02:52 PM
MAX_Xj
MAX_Xj's Avatar
ya it will spin a little bit but if you were to grab it which i dont suggest, it should stop moving, i found this out after i had the shifter plate out of my heep
1998 4dr XJ
MAX_Xj is offline
post #3 of 4 Old 04-12-2009, 03:02 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
It'll probably spin a little bit due to the friction of the oils in the transfer case.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #4 of 4 Old 04-12-2009, 03:07 PM
Opihi59
from here it gets rough
Opihi59's Avatar
When parked, can you roll under your Jeep and turn the front shaft freely when you're in 2WD? This is the way the NP231 should work, unless you have a locker in your front axle.
When I bought my Jeep, the front shaft wouldn't spin freely when in 2WD. When I rebuilt the Transfer case, I found that the mode spring had been left out, likely by whoever did some sorta maintenance on it. I replaced the spring with the rest of my rebuild, and it spins freely by hand.................at least it did until I put in an Aussie.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
YJ front drive spinning/posi-lock/no 4 wheel drive bdfletch YJ Wrangler Technical Forum 7 11-09-2009 10:58 PM
Why is front drive shaft spinning? brunolinski YJ Wrangler Technical Forum 10 06-19-2009 09:26 AM
Canniblize front drive shaft to fix the rear CV shaft? Scotch740 TJ Wrangler Technical Forum 11 11-28-2008 03:33 PM
Front drive shaft spinning in 2wd YJwolfe91 YJ Wrangler Technical Forum 16 05-29-2008 11:06 AM
Front Drive Shaft Spinning? 1goodcop TJ Wrangler Technical Forum 2 08-09-2006 11:04 AM
