Front differential vent - Page 2 - JeepForum.com
post #16 of 27 Old 02-01-2013, 12:43 PM
NHfireLJ
NHfireLJ's Avatar
Originally Posted by shayden View Post
Yes a hose clamp would work if I could get the little plastic piece attached to the hose to stay in the hole on the differential. Putting a hose clamp on the hose would just keep the little plastic piece in the hose, it would not keep in thing in the hole on the diff. Sounds a little complicated of what I am saying, maybe I could attach a pic. Would that help?
Is it broken? ie the plastic tube broke off in the housing... a pic of the housing and the end of the tube might help...
AUDREY...95 YJ UNLIMITED
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #17 of 27 Old 02-01-2013, 08:50 PM
shayden
Thats a good idea. Maybe ill look into that. Tomorrow i will post a pic to show my current situation with this. Thanks guys!
shayden is offline
post #18 of 27 Old 02-01-2013, 08:55 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Originally Posted by jbolty View Post
When I had my axle in the shop for the locker installation I had the guy tap the vent hole and screwed in a barb fitting; no more loose hoses.
This.
I use the 1/8" & 1/4" NPT brass barb fittings in my shop all the time. I've put them in axles, transfer cases, & transmissions for venting purposes.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #19 of 27 Old 02-02-2013, 03:24 PM
shayden
Ok here is a photo of the vent hose that goes into the differential. It will go into the hole just fine but it keeps popping out. Does not appear to be broken or anything and everything in the hole looks just fine. Is this plastic piece just worn out, maybe if I replace it, it will stay? I am thinking about just putting some JB Weld on it to keep it in there. Any ideas?
shayden is offline
post #20 of 27 Old 02-02-2013, 03:55 PM
NHfireLJ
NHfireLJ's Avatar
Originally Posted by Mean Max View Post
This.
Max
What Max said...
Yeah probably just worn... Do it right, or don't do it at all. Don't JB it..
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #21 of 27 Old 02-02-2013, 04:11 PM
shayden
Yeah i want to do it right for sure, even if that is replacing the little plastic piece until i can get that hole tapped. Anyone know what that little piece is called? I am on rockauto and cant find any reference to it
shayden is offline
post #22 of 27 Old 02-02-2013, 04:33 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
I doubt you'll find it anywhere except the dealer.
If it's not physically broken, use a small amount of Ultra Black RTV sealer to hold it in. The Ultra Black RTV holds better than regular RTV in an oily environment.
Max
Mean Max is offline
post #23 of 27 Old 02-02-2013, 05:17 PM
shayden
Great, will do thank you!!
shayden is offline
post #24 of 27 Old 02-02-2013, 06:00 PM
pasinbuy
I would think that jbolty has the best idea. Pull the cover and drill and tap. No more problems.
I would think it will be a easy upgrade.
pasinbuy is offline
post #25 of 27 Old 02-02-2013, 06:55 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
I agree wholeheartedly.
My suggestion should have stated that it's a temporary fix, and included the advice of tapping the hole on the next service interval.
Max
Mean Max is offline
post #26 of 27 Old 02-02-2013, 07:31 PM
PA_YJ19
I had this problem with my rear dana 44, I just pulled the old plastic one out and taped it with a 1/8 tap like stated above. Then I screwed in a 1/4 barbed fitting left over from running the hoses for my oba setup.
PA_YJ19 is offline
post #27 of 27 Old 02-02-2013, 08:30 PM
shayden
Thanks guys, sounds like that is the best way to go, which I am going to do. Appreciate everyones help!
shayden is offline
Differential vent tube keeps leaking Whipper Snapper TJ Wrangler Technical Forum 15 01-02-2009 09:32 AM
Differential "vent" bakwoodj2 YJ Wrangler Technical Forum 1 09-06-2006 08:01 PM
Differential vent line.....? peanut YJ Wrangler Technical Forum 1 10-15-2005 10:33 AM
What is the front vent under the windshield for? Jackel YJ Wrangler Technical Forum 5 09-06-2003 04:50 AM
Need help with extended differential vent hoses -D- YJ Wrangler Technical Forum 4 07-15-2001 08:36 PM
