Front caliper bolts striped - JeepForum.com
post #1 of 8 Old 09-02-2011, 12:23 AM Thread Starter
My03tj
I really need help bad. I was changing my brakes and the driver caliper bolts are stripped. I tried drilling one of the bolts and the drill bit broke in one of the groves. Can someone help me out in how to either remove the bolts or even the rotor without removing the brakes. Need to get the jeep running by Sunday.
My03tj is offline
post #2 of 8 Old 09-02-2011, 05:13 AM
I8AHUMR
Try soaking in pb blaster for a while, heat it up, and potentially use vise grips. try letting the pb soak overnight. Try several cycles of pb and heat.
93 YJ, 4.0, 4.5" suspension, 33x13.5 Pitbull Rockers, Custom scratch and dent job...
05 WK, 5.7 Hemi, Quadra-Drive II
I8AHUMR is offline
post #3 of 8 Old 09-02-2011, 05:35 AM
little_Jeep
Based upon what you are saying, the bolt (treads) are not stripped, but the head of the bolt is rounded off..... correct?
If you have a friend with a welder, weld an old nut to the rounded off head, let cool, then use wrench to remove bolt. Your local auto parts house should have a display rack with all kinds of brake hardware. This bolts should be on that rack.
little_Jeep is offline
post #4 of 8 Old 09-02-2011, 07:04 AM
Alfons
I agree, the heat from the welding will usually be enough to break the seized threads and the nut welded to the head will allow you to turn the old bolt. Before you start the welding, disconnect the battery and have the replacement bolts available to replace. For other work on the jeep, use sockets that fit the bolt - don't use adjustables or open end wrenches (these can spread enough to round the head) on bolt heads that haven't been moved for a long time.
Alfons is offline
post #5 of 8 Old 09-02-2011, 07:22 AM
little_Jeep
It's common for people to over tighten these bolts.... there is really no need for them to be upper tight. As long as the bolt doesn't back out completely, the caliper isn't going to come off. The brakes aren't going to fail.... I don't know the correct torque, but you only need the bolts to be tight enough that they won't vibrate lose.
post #6 of 8 Old 09-02-2011, 07:29 AM
Berniebikes
If you don't have a welder, use these, it did the trick for me. The extractors have a spiral grip reverse thread that tightens on the bolt head when you turn counter clockwise. When you go to replace those bolts you will be looking for a M12 1.25 pitch 35mm long, hardened to the metric equivalent of a grade 8 (cant remember what that is called). I couldn't find one so I ended up using a 40mm long bolt with two washers as spacers which I got thru fastenal.
Berniebikes is offline
post #7 of 8 Old 09-03-2011, 05:28 PM Thread Starter
My03tj
Berniebikes I bought those and it worked perfectly. Best 20 dollars ever. Thanks for the help.
My03tj is offline
post #8 of 8 Old 09-04-2011, 01:37 PM
Berniebikes
Glad it worked for you. Good luck on finding a replacement bolt.
Caliper bolts on d44 rear DominicVan91 TJ Wrangler Technical Forum 1 07-11-2011 11:33 PM
Stripped brake caliper bolts... weidmaier TJ Wrangler Technical Forum 27 01-20-2011 11:54 AM
2000 tj striped stud front hesstondc TJ Wrangler Technical Forum 2 01-14-2009 02:09 AM
caliper bolts... victory red TJ Wrangler Technical Forum 6 10-03-2007 09:36 PM
Brake Caliper bolts! ILIAMOJEEP YJ Wrangler Technical Forum 2 09-06-2002 06:38 PM
