Front bumper removal - JeepForum.com
post #1 of 11 Old 09-25-2006, 06:27 PM Thread Starter
Gif38
Anyone know for sure what size torx I need to remove my front bumper? My new bumpers came today and I plan on installing tomorrow. The only thing I dont have is the correct size torx bit.
Thanks, Jeremy
Gif38 is offline
post #2 of 11 Old 09-25-2006, 06:29 PM
Tomb Raider
Addicted...
Tomb Raider's Avatar
I want to say T-55. I have a set of em, it's the largest one in a stanley set of 3/8" socket torx.
I like to build stuff. Want to know what I build, you can google it
Tomb Raider is offline
post #3 of 11 Old 09-25-2006, 06:35 PM
lemsip
Yes its 55.
lemsip is offline
post #4 of 11 Old 09-25-2006, 06:46 PM
stilltippin
those bolts are so hard to get off w/ a torx, i just put a vice grip on there
Low Output Member #44
"There's a NEW Mexico?" -Mr Burns
stilltippin is offline
post #5 of 11 Old 09-26-2006, 06:41 AM
SimonTuffGuy
[I'm That Good]
SimonTuffGuy's Avatar
Torque Wrench FTW!
Good luck! There's 2 up top and 1 on the bottom. I got mine off with no problems. I installed some nice Grade 8 bolts in place of my Torx bits too.
SimonTuffGuy is offline
post #6 of 11 Old 09-26-2006, 07:18 AM
5.0YJ
TORX suck...mine were a pita to remove aswell
5.0YJ is offline
post #7 of 11 Old 09-26-2006, 07:25 AM
TEXASRAM
TEXASRAM's Avatar
which torx?
I just removed and replaced mine recently, just use an ALLEN Wrench, they work great. later, Rik
1995 JEEP Wrangler, 4.0 H.O. , IL6 4x4, White/Spice, Auto, Custom Center Console, Homemade Cold-Air Intake, 31x10.50x15 MT, Rubicon fenderflares, Black Denim Bestop Supertop, FlowMaster Exhaust, Hi-Flow Cat, 2" Performance Accessories Body Lift, Custom front bumper
homemade xtras to come.... rear bumper w/ tire carrier, rock sliders.........
"DON'T MESS WITH TEXAS"
TEXASRAM is offline
post #8 of 11 Old 09-26-2006, 10:08 AM
crosscheck17
i had to swing out the bumper when i installed my lights. i just used an impact wrench with a torx bit on and it came right off. i believe it is T-55. it's the same as the track-bar bolts, whatever they are.
"Flying is learning how to throw yourself at the ground and miss." - Douglas Adams
You laugh because I'm different. I laugh because I just farted.
"The box said 'Required Windows 95 or better'. So, I installed LINUX."
crosscheck17 is offline
post #9 of 11 Old 09-26-2006, 11:06 AM
JaySpencer66
The tops are not too bad to get at and to, I used a T55 and a 24 inch breaker bar. I also sprayed them out with PB blaster a few hours before and before I tried to even take them out I hit them a dozen times with an impact tool set to L for loosen. When I got them a little lose I sprayed in more blaster and then when they were up a bit more blaster yet and I sprayed from the bottom too.
(I wanted to do mine, got the tops lose and not the bottoms because I was installing tow points on the front bumper. I gave up on them when I saw how bad the bottoms were, I could not even budge them. If I have to deal with it that will be when and if I replace the bumper for any reason and at that point I may see cutting them, drilling and retapping or welding a nut on after.)
/l , [____],
l---L--[]lllllll[]-
()_) ()_)----)_)
Member #1 of the "I Hate Torx Club!"
~anyone with a Jeep is an automatic member, and anyone can be member #1~
JaySpencer66 is offline
post #10 of 11 Old 09-27-2006, 07:03 AM
Gus4x4
I used a 1/2 inch drive 4 foot breaker with a torx bit. Came out like butter. PB Blastered them the night before too....
Gus4x4 is offline
post #11 of 11 Old 09-27-2006, 10:16 AM
FarrellX
i had trouble with torx bits on my windshield bracket. stripped heads, wouldnt budge, previous owner painting over them with heavy duty paint.
went to target (just cause i was there, my plan was to go to a hardware store) and got some black and dekcer screw extractors. popped the 4 screws, that i couldnt even budge, out in about 5-10 minutes. just went to home depot and bought some hex head bolts for the replacement. taking them on and off is a breeze now, and i dont have to worry about stripping.
FarrellX is offline
Front bumper removal. ArrizX TJ Wrangler Technical Forum 15 09-27-2008 10:29 AM
front bumper removal SickSpeed JK Wrangler Technical Forum 4 05-14-2007 08:46 PM
Front bumper removal GW TJ Wrangler Technical Forum 5 04-20-2007 07:04 PM
06 tj front bumper removal -- d.mehrl TJ Wrangler Technical Forum 8 11-20-2006 08:32 PM
front bumper removal? gtex TJ Wrangler Technical Forum 9 08-03-2005 02:57 PM
