Front brakes line lock - Page 2 - JeepForum.com
post #16 of 25 Old 06-17-2013, 07:00 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
Originally Posted by TSEJEEPERS View Post
I use my hand throttle when I am on a hill and have to use 3 feet.
You don't need a line lock, you need off-road driving technique help.
1) If the motor is off, just start the Jeep motor with the clutch engaged.
2) If the motor is on, when in low gear and low range (especially if you have a 4:1 t-case), you don't need to use the gas pedal. With a foot on the brake, ease up on the clutch. There is a cross over point when the clutch + idling engine just starts to move the Jeep (you can tell by the motor starting to load up). At that point, just let off on the brake and you will start idling uphill. You probably don't even need the gas pedal, but you then have plenty of time to move your right foot to the gas.
3) If that all doesn't work, maybe because you have 3.07 gears with 35" tires and a stock 2.7 t-case ratio, then spend your money on improving the poor gearing situation.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #17 of 25 Old 06-17-2013, 07:40 AM Thread Starter
TSEJEEPERS
I have 4.56 gears, I know how to drive offroad.
I was just saying a hand throttle works well when you are stopped in a uphill situation.
My rear line lock is used as a parking brake and has worked well for 10 years or more but I do like your setup.
Was it a kit?
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #18 of 25 Old 06-17-2013, 11:26 AM
Jeepsr4me
HE asked a question about line locks , not how to drive..
Jeepsr4me is offline
post #19 of 25 Old 06-17-2013, 04:20 PM
kloppk
... With those you install a solenoid, and block off one of the lines coming out of the proportiong valve. It then goes into the solenoid, back out, then you put a tee to run the lines back out to the two front calipers.
I would think this would reduce the pressure to the front brakes...
This is what I did to my YJ. Pressure should no be affected.
I did mine with manual valves in the cab on the dash.
1 for the front brakes and 1 for the rears.
Baystate Jeepers
Deep Woods Extreme
New England 4 Wheelers
kloppk is offline
post #20 of 25 Old 06-17-2013, 08:22 PM
NHfireLJ
NHfireLJ's Avatar
works great!!!
AUDREY...95 YJ UNLIMITED
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #21 of 25 Old 06-17-2013, 08:43 PM Thread Starter
TSEJEEPERS
Thanks kloppk after all this drama someone answered my original question.
post #22 of 25 Old 06-17-2013, 08:45 PM Thread Starter
TSEJEEPERS
Originally Posted by NHfireYJ View Post
works great!!!
So are either you or JeeperDon going to tell us whether this is a kit or not?
Or would you both rather show us pictures of your setup?
post #23 of 25 Old 06-17-2013, 09:02 PM
NHfireLJ
NHfireLJ's Avatar
Tom woods rotor kit!
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #24 of 25 Old 06-17-2013, 09:13 PM Thread Starter
TSEJEEPERS
Thanks
post #25 of 25 Old 06-17-2013, 10:07 PM
JeeperDon
JeeperDon's Avatar
The rotor kit needs fab work to get it to mount to whatever SYE or aftermarket tcase you may have. It only works with a plate type output flange, not the yoke type. I welded a bracket to the inside of the frame to hold an overhead garage door pulley, which turns the OEM parking brake cable 90 to operate the rotor brake. It's been in service for me for 8+ years now.
Web Admin for
