Front brake line size-Hard line?? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Front brake line size-Hard line??
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRough Country Deals at JeepHut.comJeep JK Wrangler 3" Suspension Lift Kits $439.99 deli
Unread 07-14-2007, 02:59 PM   #1
learfxr
I'm trying to finish up my D44 install and want to install new brake lines to the calipers, well the fitting from the rubber line to the hard line is jacked. I tried to use a line wrench to work it loose and it still rounded off. I had to pull the whole hard line out. What size tubing do I need to replace this stuff? I'm wanting to order some tube and make my own new lines, but don't know what size. Anyone know??? This happened on both sides. I'm hoping I can cut off the RH side fitting and install a new fitting without running a whole new line. Now I have to buy all the tools. Just what I wanted to do. I could probably salvage the LH side hard line, but I may have bent it up removing it. The lines at the valve were easy to remove. Whoever installed the BDS lift must have never wanted a brake line leak. They sure went crazy on the fittings.
1989 YJ
TBI350 4L60E from 94 Yukon
Rockwells and 47's under construction
2000 TJ The wifey rig
3.5" and 1" body, 8.8 swap, 35's and 4.88's
learfxr is offline   Reply With Quote
Unread 07-14-2007, 04:38 PM   #2
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
Big-n-Broke-YJ's Avatar
most every regular vehicle uses 3/16" hardline... as does your jeep... and did the vehicle your axles came out from under.
autozone and advance.. and most every parts store will have plenty of it in stock.
-Erik
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs
March 1st, 8pm. WILMINGTON, NC MEET & GREET @ HOOTERS!
Big-n-Broke-YJ is offline   Reply With Quote
Unread 07-14-2007, 04:57 PM   #3
pasinbuy
I rounded a few on mine also. Use vice grips if you don't feel like repacing.
pasinbuy is offline   Reply With Quote
Unread 07-14-2007, 06:40 PM   #4
learfxr
Thanks Erik. Saw your rig in the Mag this week. Bought it at the airport in Oregon.
I bought a cutter, bender and flaring tool at O'Reilly but they couldn't find any fittings to replace mine. I'll have to wait til monday to get them at Napa. I ordered new rubber lines from Napa this morning to bolt up to the D44 calipers and they should be in Monday too. I cut the RH side off just behind the fitting so I can take it to Napa with me and maybe I'll get the right part the first time, well that never happens.
1989 YJ
Unread 07-14-2007, 07:24 PM   #5
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
thanks man!
hopefully you'll be set to get brakes on it monday without too many issues....
