Front Bearings - JeepForum.com
post #1 of 10 Old 02-16-2014, 04:58 PM Thread Starter
Mark05059
Front Bearings
I know this is kind of an odd question but Im looking for the bolt circle of the mounting hub. Im also looking to find what the center hub area is.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #2 of 10 Old 02-17-2014, 05:40 AM Thread Starter
Mark05059
anyone?
1998 ZJ 5.2 Auto
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
post #3 of 10 Old 02-17-2014, 07:47 AM
Jeepsr4me
Maybe explain your question a little better, as is I am having a hard time understanding what you want
Jeepsr4me is offline
post #4 of 10 Old 02-17-2014, 07:59 AM Thread Starter
Mark05059
where the attaching bolts are... there are 3 bolts in a concentric circle. I want to know what that circle is.. I know the wheel studs are on a 4.5 inch circle.
1998 ZJ 5.2 Auto
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
post #5 of 10 Old 02-17-2014, 08:14 AM
jsawduste
2006 YJ Wrangler
Perhaps go to a parts store with a piece of cardboard and a sharpie ?
I like where your going with this.
jsawduste is offline
post #6 of 10 Old 02-17-2014, 11:07 AM
Jeepsr4me
U trying to find a bearing that will fit that hole but have a different pattern? Most parts stores have calipers to measure outside and inside diameter. Just go up there and get them to pull a hub unit and measure the outside diameter of the mount.
If they ask why, say you need to make sure it will fit the hole you have.. They dont care either way.
post #7 of 10 Old 02-18-2014, 04:52 AM Thread Starter
Mark05059
so here is the real reason I want to know this. I am building a trailer to go behind the jeep and want to have the same bolt pattern as the towing vehicle. I also would like to build this to "squat" so a full axle wont work.
1998 ZJ 5.2 Auto
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
post #8 of 10 Old 02-18-2014, 06:54 AM
CJ51973
CJ51973's Avatar
FYI...U have to install outer shafts in the unit bearings or they will come apart
Anything is possible if you don't know what you are talking about.
CJ51973 is offline
post #9 of 10 Old 02-18-2014, 07:05 AM
Jeepsr4me
YEAP what he said^^^... Can get front cherokee 2x4 axle. And it already has the stub axles in there. Very easy... No monkeying around with making something work.. Get hub bearings and all at a U pull it yard for less than 40 bucks.
post #10 of 10 Old 02-18-2014, 07:33 AM
Jeepsr4me
Or if you wanting just the lug pattern, any for ranger or explorer front 2x4 axle with be spindles and rotor. A much easier setup to use and the bearings last forever.
