Front axle vacuum disconnect interrupt idea, will it work? - JeepForum.com
post #1 of 6 Old 07-25-2007, 10:27 PM Thread Starter
ElvisV04290
ElvisV04290's Avatar
My front axle disconnect is still the stock vacuum disconnect setup. I was thinking, what if I took one of my old vacuum switches (from the pulse air system control on the valve cover) and put it in line with the vacuum pulled off the manifold for the 4wd system. This way, I could turn off (close) the switch and not allow vacuum to reach the transfer case. Then if I were to shift into 4 low, it would really be 2 low since the front axle shift fork will not move. Think this would work? And can the vacuum switch take 12 volts? or will I need to find a place that has lower voltage to pull from?
1990 YJ, Colorado Red with 'Laredo' markings, 4.2L, TF999, NP231, Valvoline Syn fluids, Weber 32/36, Nutter Bypass, Dana 30/35, 16" Electric Fan, Optima Yellow Top, 140amp alt., K&N Air Filter, Cherry Bomb muffler, SRC Front Bumper, CH&F Shackles, KC 100w Daylighters, Homemade Lightbar, Rear Aux lights, Cobra CB/PA/WX, 102" Whip Ant., 400 watt power inverter, 2 fire extinguishers, Mobile Internet & WiFi equipped.
Daily Driver since April 23rd, 2003
Northern Illinois Extreme Jeep Club Member
Weber 32/36 Install ->
Early YJ Club Member #37
For anyone with a 4.2L -->
ElvisV04290 is offline
post #2 of 6 Old 07-25-2007, 10:51 PM
goatboy
Sounds good, but I'm wonderin' why you wouldn't wanna pony up for a PosiLock and not only have something which will do just that, but will also eliminate a source of problems...sure, I realize that it's expensive, but it's also a dependable, well built piece...
goatboy is offline
post #3 of 6 Old 07-25-2007, 10:58 PM Thread Starter
ElvisV04290
I just replaced everything on my disconnect system last year, it's all new and working great. So why replace that all again so soon? And I already have the switch, so it's not like I'm spending any money, just some of my time.
post #4 of 6 Old 07-25-2007, 11:07 PM
oldballz
oldballz's Avatar
2011 JK Wrangler
i agree with goatboy the posilock is a great piece of gear. i just recently installed one and a cast shift fork, took just over an hour. its quick easy and painless, plus you can run 2Low if you needed to.
oldballz is offline
post #5 of 6 Old 07-25-2007, 11:18 PM Thread Starter
ElvisV04290
You are missing the point, I asked if this could be done, not if there is a better option. I'll just do it and if worse comes to worse I'll fry a vacuum switch in the process.
post #6 of 6 Old 07-25-2007, 11:20 PM
goatboy
Please accept my apologies for pooin' in your mess kit...rest assured I will not go there again...
goatboy is offline
vacuum axle disconnect. i know i know. jbach YJ Wrangler Technical Forum 5 09-12-2009 02:51 PM
Vacuum disconnect axle in to a TJ? hypnotikrobot TJ Wrangler Technical Forum 7 03-03-2009 12:15 AM
YJ front axles vacuum connect/disconnect Furry YJ Wrangler Technical Forum 8 06-24-2008 07:59 AM
How is the front axle disconnect suppose to work? jzmtl YJ Wrangler Technical Forum 9 11-24-2006 10:49 PM
Front Axle disconnect vacuum diagram Wrangler Man YJ Wrangler Technical Forum 2 11-16-2002 08:23 AM
