Front axle spider gears welded, DD - JeepForum.com
post #1 of 11 Old 11-12-2009, 04:29 PM Thread Starter
yjjeepn92
I was just curious as how hard it would be on the front axle if i welded my spider gears together. it is a daily driver and i have the stock D30 w/ 4.56 gears. Im just wondering how hard it would be on the front end. I would go with a locker but i am on a limited budget.
thanks!
yjjeepn92 is offline
post #2 of 11 Old 11-12-2009, 04:32 PM
justanotherjpr
It will be really hard on your front end, especially if you don't have a disconnect axle or have converted to a solid shaft. Expect to break a lot of U joints of you are running disconnect shafts. Welded front or rear is an awful idea for any DD, IMO.
Do you drive in the snow at all?
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline
post #3 of 11 Old 11-12-2009, 04:32 PM
MudDuck99
2014 JK Wrangler
it would be worth it to save the money for a locker. Your jeep would handle horrible,un-even tire wear, and you would lose the tight turning radius that wranglers are famous for
MudDuck99 is offline
post #4 of 11 Old 11-12-2009, 04:32 PM
MudDuck99
2014 JK Wrangler
not much snow down south
post #5 of 11 Old 11-12-2009, 04:37 PM
jeepercreeper77
jeepercreeper77's Avatar
i see that people are welding the spider gears if they have a disco front axle. the only problem i've heard of is that the disco parts breaking(fork,collar).
90 wrangler,4.2l,1" MML,CRT HEI Dist.,34/34(interco) weber, hurst shftr,5spd,5" BDS lft,f-d30/r-8.8,5/8 lft booms,1" bl,tflex belly up,JB convs. SYE,gdyr mtr35s,hurc'ed,smit src frt bump,gen-r rear bump w/tire carrier,f&r tube fenders,psc knokrs,r gen-rgt ful conr gurds,duel bat.,BIC,m8000
jeepercreeper77 is offline
post #6 of 11 Old 11-12-2009, 04:58 PM
Louie4
I've also seen a lot of folks welding up the front. As long as the disconnect is operable (like everyone else said) you should be fine. The most problems I've heard about seem to be busted u-joints.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is online now
post #7 of 11 Old 11-12-2009, 07:21 PM Thread Starter
yjjeepn92
yeah not a whole lot of snow down here. but i was thinking about a limited slip in the front but just curious about that. the aussie lockers seemed to be liked alot. is there any difference between the aussie's and a detroit?
post #8 of 11 Old 11-12-2009, 07:26 PM
ImpactFabWorks
mines welded and i drive it everyday. as long as your axle disconnect works you don't even notice it.
1990 YJ = The Toy/ My Daily Driver
1996 XJ= Wifes Daily Driver
Please fill out your profile, It helps us help you!!!
ImpactFabWorks is offline
post #9 of 11 Old 11-12-2009, 07:39 PM
Louie4
I wouldn't waste my time with a limited slip. I run a Lock-Right up front but I don't notice it because of the disconnect. However, I did get my front driveshaft straightened and balanced because of vibrations.
Lou
YJOTM July 2012
YJOTM February 2014
post #10 of 11 Old 11-15-2009, 07:39 AM Thread Starter
yjjeepn92
how much do the lock rights run for a d30
post #11 of 11 Old 11-15-2009, 07:46 AM
Jeepsr4me19
1976 CJ5
Aussie is only 249.
Jeepsr4me19 is offline
Driving with no spider gears in front diff? mbuna TJ Wrangler Technical Forum 12 05-28-2012 03:55 PM
Removing side gears and spider gears... Mudbug1979 TJ Wrangler Technical Forum 2 10-08-2009 06:34 AM
Custom front axle help spider 9 with TJ or Chevy 44 Knuckles gcally TJ Wrangler Technical Forum 11 02-03-2009 05:45 PM
welded spider gears with a posi lok? sitdwnandhngon YJ Wrangler Technical Forum 8 03-27-2008 09:01 PM
welding front spider gears... possible to undo or is the carrier trash? Big-n-Broke-YJ YJ Wrangler Technical Forum 18 07-14-2007 07:25 PM
