front axle shift fork broke - JeepForum.com
post #1 of 3 Old 06-19-2001, 01:09 PM Thread Starter
Tonka
2015 JK Wrangler
Ah, I knew that the month log break free streek would end soon. Pulled the dreaded vaccuum disconnect today and the shift fork broke as suspected.
This leads to my question.
What , if anything, has any one done to keep this thing engauged all of the time, besides the posi lock or swapping shafts? I rigged my old xj with a couple of sway bar link bushings and screws, but dont have the room to do so on the yj. The fork broke at the shift motor(a.k.a. vaccuum thingy).
98 TJ
90 MJ short bed converted to 4x4
90 XJ 2 dr 4x4
Tonka is offline
post #2 of 3 Old 06-21-2001, 12:40 AM
jpwranglr9
i swoped shafts but what we did to my buddies is take a few washers. (3/8" i think) but just pull out the E clips out of the shaft and remover the indicator switch from the one end and tap the shaft out the other side (twords the vacume). rember where the shift fork goes both on the shaft in which side its on to lock in the axle. the put enough washers on the shaft so that it keeps it over to the side you want. then when you bolt everything up, make shure that you are in the center of the two shafts. thats it. plug your vacume lines. the indicator light is the toughest thing. i had a JB conversion on my 231 so i put it in the rear of that where the shift rod can hit it. hope this helps. E-mail me if you need some more help.
JPWranglr9@aol.com
Its not what you buy...its what you BUILD!!!
1995 YJ ,SOA with 4" procomp front 3.5" BDS rear 1" shackle rear, custom stearing, 35x12.50x15 pro-comp MTs, warn xd9000i, on-board air from A/C, dana 44 rear and 30 front with 4.56, powertrax no-spin rear, custom disks rear/trutrac front, warn front shafts, HD SYE kit, HD front and rear driveshafts, Warn 4X flairs, PIAA 520 ligts and on and on and on :)
jpwranglr9 is offline
post #3 of 3 Old 06-21-2001, 02:29 AM Thread Starter
Tonka
2015 JK Wrangler
yup, thanks!
98 TJ
90 XJ 2 dr 4x4
Tonka is offline
front axle disconnect shift fork, broken AGAIN John Snyder YJ Wrangler Technical Forum 8 11-04-2013 09:37 AM
4 WD Front Shift Fork/Collar denalione YJ Wrangler Technical Forum 5 01-30-2010 07:56 AM
Front Shift Fork worn? Greatwhite007 YJ Wrangler Technical Forum 3 01-24-2007 09:05 PM
Shift fork? lah2420 YJ Wrangler Technical Forum 5 06-09-2006 07:37 PM
front wheel drive shift fork hguffman YJ Wrangler Technical Forum 10 12-04-2003 08:54 AM
