front axle seal - JeepForum.com
post #1 of 6 Old 08-16-2011, 06:36 PM Thread Starter
kjg26
kjg26's Avatar
front axle seal
I.just replaced the passenger side axle u.joint. went out tonight and noticed little bit of diff fluid on.the ground and on.the knuckle. Did I need to grease anything up.putting axle shaft.back.in? Did I trash the seal? I'm hoping that was.just the remainder of the
Black 1993 YJ 4.0, 5 Speed
Slowly but surely getting better and better. Trailer build soon!!
kjg26 is offline
post #2 of 6 Old 08-16-2011, 06:36 PM Thread Starter
kjg26
kjg26's Avatar
Remainder of the diff fluid that got lose during shaft removal.
kjg26 is offline
post #3 of 6 Old 08-16-2011, 08:11 PM
timatoe
timatoe's Avatar
I'd just wipe it all down and drive it, check it in a couple of days and see if more lube has come out. It's very possible that what you're seeing is just lube that's gotten past the seal when pulling the shaft. If it's still leaking though you're likely gonna need a new seal.
timatoe is offline
post #4 of 6 Old 08-16-2011, 09:40 PM Thread Starter
kjg26
kjg26's Avatar
rock on. thanks! thats what i figured. I couldn't figure out why my garage stunk...until now. LOL. Thanks everyone! New Seal is replaced from the inside isn't it? From the vac disconnect area?
kjg26 is offline
post #5 of 6 Old 08-17-2011, 07:44 AM
firefighter315
Yes, that seal is just outboard of the vac disconnect.
My YJ Build Thread
firefighter315 is offline
post #6 of 6 Old 08-17-2011, 08:37 AM
johnboy68
HIP2BSQR
johnboy68's Avatar
It is a PIA to replace without the right tools. I spent 2 days and 2 seals before stopping to get the correct tools for the job. Now I can replace one in about an hour.
Do a search and you will find the post with part numbers for the tools needed. They are a little pricey. I went the cheap route and got the universal seal press kit from Harbor Freight and used my drill and bench grinder to size the closes one down to fit the seal. With some all-thread, couple nuts, some fender washers and the customized seal press I can have the old one out and the new one in in no time.
-John-
johnboy68 is offline
