front axle prob-please help! - JeepForum.com
post #1 of 6 Old 09-27-2001, 05:31 AM Thread Starter
hardoncj5
i think there is something wrong with the front engage-disengage system (yj'89)
can someone send some pics or a diagram of the vacuum hoses and the proper connections?
any info would be apreciated
thank you
hardoncj5 is offline
post #2 of 6 Old 09-27-2001, 04:23 PM
shea324@aol.com
Whats wrong with your axle is the design. Save youself the trouble and go to www.quadratec.com and search for "posi-lok". This will solve your problems.
90' YJ Four Banger, 2" Lift, 31" Tires, Many Mods to come
shea324@aol.com is offline
post #3 of 6 Old 09-27-2001, 08:38 PM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
I think I have a problem as well with mine right now. My front driveshaft is "connected" to the front axle .. when the drivers wheel turns, so does the driveshaft. When the passenger wheel turns, the driveshaft stays still.
My driveshaft used to be fully dis-engaged .. I could spin it freely by hand with all tires on the ground, and I can't anymore.
Any one with ideas on what to look at? Is it the gears, or the vacuum actuator?
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #4 of 6 Old 09-27-2001, 09:25 PM
JeeperJay
That is another design flaw with the D30. The drivers side axle shaft will always spin the differental and driveshaft even if the 4WD is not engaged, but since the transfer case is not disributing power to the front wheels its is still considerd 2WD. Its a characteristic of the D30 that makes for bad on-road handling. The only way to fix it is to lose the D30
1992 YJ, 2.5L 4-banger, 2" Lift, 31x10.5 BFG Mud Terrain, K&N Filter, Restrictor Removed, Hi-Lift, Custom bumpers, More to come...
JeeperJay is offline
post #5 of 6 Old 09-28-2001, 06:03 PM
jpwranglr9
your disconect is fine. something is up in the differential. yes your driver side driveshaft is always connected but when in 2wd, your spider gears should spin letting you freely turn your driveshaft. likewise you can turn your both wheels independent of each other and of the driveshaft. if you have a limited slip or places a locker in the front, this will cause you driverside wheel to always spin the driveshaft due to no spiders. If you dont have a limited slip or a locker, then there may be something wrong with your spiders in the front carrier. try to spin the driveshaft while all wheels are on the ground. if it doesn't turn either directions then pull the cover, drain the fluid and check the spiders. make sure they didnt get jammed. if it does spin, than you are ok. it may take some force. dont worry about the spining driveshaft when you are driving if it checks out ok...there is no load on it.
Its not what you buy...its what you BUILD!!!
1995 YJ ,SOA with 4" procomp front 3.5" BDS rear 1" shackle rear, custom stearing, 35x12.50x15 pro-comp MTs, warn xd9000i, on-board air from A/C, dana 44 rear and 30 front with 4.56, powertrax no-spin rear, custom disks rear/trutrac front, warn front shafts, HD SYE kit, HD front and rear driveshafts, Warn 4X flairs, PIAA 520 ligts and on and on and on :)
jpwranglr9 is offline
post #6 of 6 Old 09-28-2001, 08:17 PM
NaeKid
NaeKid's Avatar
I think that my front driveshaft is not balanced properly .. anything over 100km/h (60mph) and my front shakes like a leaf in a tornado.
I was thinking the spidergears might be the problem .. but wasn't sure. I will take it apart and verify this real soon (the weather is supposed to be nice soon, so I can work in the sunshine).
Thanks!
Silver
NaeKid is offline
axle prob CreepyCrawler95 YJ Wrangler Technical Forum 0 07-27-2009 09:14 AM
8.8 axle brake prob cj60jeep Wrangler General Discussion 3 12-02-2008 09:02 PM
prob with the front of it slamin81 TJ Wrangler Technical Forum 4 04-09-2008 10:20 PM
front driveshaft/auto tranny skid prob Texas TJ TJ Wrangler Technical Forum 6 04-22-2006 07:47 PM
Front end alignment prob Spiderman TJ Wrangler Technical Forum 18 04-25-2004 08:26 PM
