Front Axle Passenger side U-Joint Question - JeepForum.com
post #1 of 5 Old 08-08-2011, 01:37 PM Thread Starter
94Moby
How much play would worry you guys? Just nosing around the rig yesterday, I decided to pull on the front axle u-joints. The drivers side is good-n-tight, but the passenger side will "click" when I give it a twist. For those who know: is this something that should get instant attention, or is this something that could stand to be left for a while? Not wheelin' full time as yet, but I am thinking of throwing in a lunchbox when the wife isn't looking...
94Moby is offline
post #2 of 5 Old 08-08-2011, 01:42 PM
jbolty
jbolty's Avatar
No problem at all, unless it breaks and takes out the seal or breaks the ears off the outer or inner shaft. Spend the $20 and take the hour to get it done.
jbolty is offline
post #3 of 5 Old 08-08-2011, 01:45 PM
JEEP_Nut1218
Agreed, if you've got it out already then just throw a new one in. Can't hurt
'90 YJ with some stuff
I'm a pic whore, get over it.
JEEP_Nut1218 is offline
post #4 of 5 Old 08-08-2011, 04:58 PM
MLJeeper
MLJeeper's Avatar
Tell the wife the u joint is worn out BECAUSE there is no locker in there.
Replace the joint, you do not want the collateral damage if it goes under a load.
Your limited slip differential sucks.
Any video of the sound?
MLJeeper is offline
post #5 of 5 Old 08-08-2011, 06:45 PM Thread Starter
94Moby
94Moby is offline
Passenger side front axle leaking PrinothPro YJ Wrangler Technical Forum 9 11-17-2009 05:26 PM
TJ--Front Axle shifted to passenger side cseifert TJ Wrangler Technical Forum 7 09-18-2009 10:10 PM
Front passenger side axle leaking grnsporty TJ Wrangler Technical Forum 6 07-17-2009 10:32 PM
90 model passenger side axle shaft u-joint? rivers edge YJ Wrangler Technical Forum 9 05-16-2008 05:55 AM
Front axle is shifted over to passenger side CaliforniaKid TJ Wrangler Technical Forum 15 04-08-2008 08:08 AM
