Front axle engagement - JeepForum.com
post #1 of 8 Old 09-22-2010, 03:13 AM Thread Starter
staush
don't know much about the vacum dis-connect but,on mine two vacum hoses are missing but the 4 wheel drive seems to engage.I haven't had it mudding yet just going by the way the front tires grab when you hit solid ground.Any ideas?Want to go muddin' but would like things to work when I need them.Thanks
staush is offline
post #2 of 8 Old 09-22-2010, 05:04 AM
johnboy68
HIP2BSQR
johnboy68's Avatar
Search - There are a lot of threads already that show you how your Center Axle Disconnect (CAD) works and how to test it to make sure it's engaging.
-John-
johnboy68 is offline
post #3 of 8 Old 09-22-2010, 05:10 AM
Jeffro06
Jeffro06's Avatar
If you're not the original owner it could be that the two piece axle has been replaced with a TJ shaft, thus eliminating the disconnect.
Jeffro06 is offline
post #4 of 8 Old 09-22-2010, 06:27 AM Thread Starter
staush
Something else,I noticed when I replaced ball joints and put axles back in when I turned them(both sides) the drivesaft turned.Normal?or does it mean something?
staush is offline
post #5 of 8 Old 09-22-2010, 06:31 AM
vanwyk4257
Someone could also have manually moved the shift fork in the front axle and re-inserted one of the e-clips to permanently engage the collar on the 2-piece axle on the passenger side.
2010 Jeep JK Wrangler Unlimited Sport - Red Rock
FOR SALE - Asking $26000 OBO.
vanwyk4257 is offline
post #6 of 8 Old 09-22-2010, 06:34 AM Thread Starter
staush
not to sound?but what does that mean?
staush is offline
post #7 of 8 Old 09-22-2010, 06:54 AM
vanwyk4257
There is a shift fork inside the CDA housing where the vacuum lines normally connect. The vacuum motor moves the shift fork back and forth sliding a collar either engaging or disengaging the 2-piece passenger side front axle. The shift fork rides on a shaft and is held in place laterally by two e-clips. It is possible to remove an e-clip, move the shift fork to the "locked" position and reinsert the e-clip, thus permanently engaging the front axle. Hope that helps.
post #8 of 8 Old 09-22-2010, 06:59 AM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
Here is what you should do. this will be educational for you and allow us to tell you whats going on with your pile.
On the passenger side of the front axle, look at the vacuum disco box on the back side of the axle tube. 4 bolts hold that box in place. removed those 4 bolts with an oil catch pan under the it. The entire vacuum disco cover will come off
here is what it looks like with the cover off. This is Stock.
what do you see on yours? If it looks just like my picture in your axle tube. Look in the cover you removed, take a picture of the fork and actuator rod and post it up.
Originally Posted by ionakana
don't post threads that poke Poke!
Poke is offline
shafts in front axle moving at engagement point schizm99 YJ Wrangler Technical Forum 3 05-06-2009 01:00 PM
Superior Axle & Gear EVOLUTION SERIES Front Axle Tube Seals 95wrangler4life YJ Wrangler Technical Forum 3 02-17-2009 02:00 PM
Front axle engagement alternative pajeep YJ Wrangler Technical Forum 0 01-25-2009 11:15 AM
TJ front axle engagement??? julietkilo TJ Wrangler Technical Forum 14 11-03-2004 02:37 AM
Posi-Lok axle engagement system JKNIPE2000 YJ Wrangler Technical Forum 2 09-24-2004 03:28 PM
