Front Axle Disconnect Vacuum Elimination - Page 3 - JeepForum.com
post #31 of 41 Old 01-01-2011, 12:55 PM
timatoe
timatoe's Avatar
Originally Posted by awkrueger View Post
Does anyone have any experience with switching to tj shafts? My plans was to swap shafts and pick up a Tom Woods front shaft. Any thoughts on this route?
I swapped in TJ/XJ shafts and had zero issues.
timatoe is offline
post #32 of 41 Old 01-01-2011, 04:52 PM
jonzjeepyj
Like I said, I did swap in the TJ/XJ solid, right, front shaft with no problems.
What I was trying to say is that it killed my MPG as I use my rig as a DD.
Other than that, I have had no problems. I went from 16-18 Mpg to about
11-13 Mpg
92YJ/2.5L/5-Speed/D30-35/4.88's/AX5/N231J
TeraFlex High Steer Kit/Solid Front Axle Conversion
Super Coil/Live wires/14" E-Fan/4L TB/19lb Injectors
AA-SYE/CV Rear DS/1" Lift S-Reversal Kit Up Front
1" lift Shackles Rear/4" RC Lift SUA/1" Daystar Body Lift
Hack and Cut Flatty Front Fenders/TJ Rear Fender Flairs
35x12.5x15 BFG TA KO's/15x10 AR Outlaw 1 Wheels
High Lift Jack/D-Rings/9000lb Winch/Tow Hooks
There is no problem that can't be fixed if you throw enough money at it.
jonzjeepyj is offline
post #33 of 41 Old 01-01-2011, 05:58 PM
YJames90
YJames90's Avatar
Originally Posted by YJames90 View Post
I had a perfectly working vac system and replace it with a posi loc after installing the Aussie. . Last month i got it onto my head that i wanted to remove the PL and install a solid shaft.
My next thought was to keep the stock shaft and just put the factory vac housing back in and just permantly e clip the fork over to the connected posistion as it is now.
I now get a vibe while driving can picture that wheel on the lock out fork spinning unnecessaraly
I will be reinstalling the posi lok today
Posi-lok is back in and working
My 2.5 to 4.3 swap thread
YJames90 is offline
post #34 of 41 Old 01-01-2011, 06:19 PM
Louie4
I still run my stock system. It's only been problematic once when it wouldn't disengage but a some carb cleaner and WD-40 fixed that.
I also re-routed a 3 way toggle vacuum switch that I got off a Wagoneer at the junkyard. It worked great but after I got a locker and ripped the 4wd switch out of the axle I just hooked up the original system. Since the switched was ripped out on the trail I couldn't visibly tell if my axle was engaged or not and would not disengage it sometimes.
I ended up sending the switch a member on JF for free and now I'm planning on new XJ shafts once the stock system fails but that's just my .
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #35 of 41 Old 01-01-2011, 06:29 PM
YJames90
YJames90's Avatar
Havent hooked up the 4wd light wires yet, maybe on the next warm day. today was weird weather with temps in the 50s
YJames90 is offline
post #36 of 41 Old 02-24-2013, 09:28 PM
mcintry
1987 YJ Wrangler
I know this an old post but has anybody attempted to build an electric piaton/actuator to control the disconnect instead of vacuum
mcintry is offline
post #37 of 41 Old 02-24-2013, 09:37 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Someone tried one with an electric actuator. Its just so much easier to lock the fork over and not have to mess with any go go gadget buttons.
Luck Favours The Prepared
Anticanman is offline
post #38 of 41 Old 02-24-2013, 10:02 PM
mcintry
1987 YJ Wrangler
But locking it over is all the time 4wheel i never cared for that perfer the ability to disconnect was there a right for the electric actuator design or was it a store bought setup
mcintry is offline
post #39 of 41 Old 02-24-2013, 10:04 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Four wheel drive is determined by the selection on the transfer case. Not the front axle.
post #40 of 41 Old 02-25-2013, 09:55 AM
JOExFROMxNY
Maybe he meant "all the time spinning the driveshaft"
JOExFROMxNY is offline
post #41 of 41 Old 02-26-2013, 08:07 PM
mcintry
1987 YJ Wrangler
Yea that is what i meant
mcintry is offline
How to: Vacuum Disco Elimination, Axle Tube Sleeve Fix, ubolt eliminator - 56K beware Joe Dillard YJ Wrangler Technical Forum 48 02-17-2016 05:39 AM
Front axle OEM lower shock mount elimination? toyrocs TJ Wrangler Technical Forum 10 11-09-2009 09:08 PM
vacuum axle disconnect. i know i know. jbach YJ Wrangler Technical Forum 5 09-12-2009 02:51 PM
Front axle vacuum disconnect interrupt idea, will it work? ElvisV04290 YJ Wrangler Technical Forum 5 07-25-2007 11:20 PM
Front Axle disconnect vacuum diagram Wrangler Man YJ Wrangler Technical Forum 2 11-16-2002 08:23 AM
