Front Axle disconnect vacuum diagram - JeepForum.com
post #1 of 3 Old 11-15-2002, 11:39 PM Thread Starter
Wrangler Man
Does anyone have a vacuum diagram for the front axle disconnect that shows where the red line is supposed to hook to. There is one floating around that is good for the shift motor, and transfer case but it does not indicate where on the engine vacuum system the red one hooks too.
Wrangler Man
1987 Wrangler YJ 4WD
Hard Top
Rino Lined interior
Project Jeep
Want to add a 4" lift, winch
Wrangler Man is offline
post #2 of 3 Old 11-16-2002, 01:52 AM
AllanAlxndr
Here is this one...
I am not sure of any others. It should connect to a line coming from the manifold somewhere... If I get a chance tomorrow. I will dig around on my Jeep and get a picture(s) of the lines...
HTH
***What do I know, I just cause Problems***
*'90 Wrangler*
*4 Banger*
*6" of lift, (4" suspension, 2" body)*
*33" ATs on Outlaw II's*
*Pioneer DEH3500/CD deck*
*1800WATT Amp w/ Custom Box*
*2 - 8" Rockford Fosgate HEs*
*Cobra 18WXSTII w/ 4' Firestik Antenna*
Member of
AllanAlxndr is offline
post #3 of 3 Old 11-16-2002, 08:23 AM Thread Starter
Wrangler Man
vacuum diagram
Thanks
This is the diagram that I have seen. I have searched everywhere whitout success for a good vacuum diagram other than this one and the emmission control vacuum diagram. You would think there would be something.
Wrangler Man
Hard Top
Rino Lined interior
Project Jeep
does anybody have a diagram of the vacuum lines for the front axle? bustemduck YJ Wrangler Technical Forum 21 03-06-2012 03:04 PM
vacuum axle disconnect. i know i know. jbach YJ Wrangler Technical Forum 5 09-12-2009 02:51 PM
Vacuum disconnect axle in to a TJ? hypnotikrobot TJ Wrangler Technical Forum 7 03-03-2009 12:15 AM
YJ front axles vacuum connect/disconnect Furry YJ Wrangler Technical Forum 8 06-24-2008 07:59 AM
Front axle vacuum disconnect interrupt idea, will it work? ElvisV04290 YJ Wrangler Technical Forum 5 07-25-2007 11:20 PM
