front axle disconnect shift fork, broken AGAIN - JeepForum.com
post #1 of 9 Old 04-26-2003, 08:27 PM Thread Starter
John Snyder
I have broken my front axle disconnect shift fork two times in the last year. I am always very careful when I shift into or out of 4wd. What else in the 4wd system could be broken that would continue to break this shift fork.....
please let me know if this has happened to anyone else......
thanks
johnny1720
92 YJ: Canary Yellow
4.0 HO
AX15
K&N
3.5 Inch BDS
Brush Guard
SONY Head Unit
Besttop Overhead speaker console
John Snyder is offline
post #2 of 9 Old 04-27-2003, 12:15 AM
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
what part of the fork broke? one of the tines? the hole for the shaft? one of the wear clips?
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline
post #3 of 9 Old 04-27-2003, 01:43 PM Thread Starter
John Snyder
the top hole on the fork
the top hole on the fork keeps breaking...
4.0 HO
AX15
K&N
3.5 Inch BDS
Brush Guard
SONY Head Unit
post #4 of 9 Old 04-27-2003, 08:00 PM
sentinal02
sentinal02's Avatar
that means that the collar isn't sliding easily enough, which causes your fork to kick at an angle putting too much bending force for the hole to take. i'm surprised that the vacuum motor has enough force to break that though. try moving the collar by hand and see if it feels like it's binding up. remember, you may have to turn the axle shafts a little to get the splines lined up. if it moves freely, then i would suggest getting an after market steel fork instead of the stock one, if you haven't already. that would be where i would start trouble shooting. HTH
post #5 of 9 Old 04-27-2003, 08:14 PM
Gator
2 options
1. get the cable operated engagment system
or
2. put a Tj shaft on the passenger side & dont ever worry about the Vaccum crap again
Gator is offline
post #6 of 9 Old 04-27-2003, 09:27 PM Thread Starter
John Snyder
where do i get an aftermarket steel fork
I ordered 2 repacement forks from 4wd.com they were really cheap so i got an extra.
I am also surprised that it has enough force to break that stupid fork...
I will be posting pictures very soon of my baby...
4.0 HO
AX15
K&N
3.5 Inch BDS
Brush Guard
SONY Head Unit
post #7 of 9 Old 04-27-2003, 10:53 PM
sentinal02
sentinal02's Avatar
i looked at replacing my forks when i did my posilok, and i found that most places listed two different forks that would work. one was aluminum and the other was steel. are you sure the ones you got were the steel?
post #8 of 9 Old 04-28-2003, 05:45 AM Thread Starter
John Snyder
i will have to call and check thanks
I will have to call and check thanks I had no idea there was a steele one...
4.0 HO
AX15
K&N
3.5 Inch BDS
Brush Guard
SONY Head Unit
post #9 of 9 Old 11-04-2013, 10:37 AM
jojojeep1
can you replace the wear clips
jojojeep1 is offline
4 WD Front Shift Fork/Collar denalione YJ Wrangler Technical Forum 5 01-30-2010 08:56 AM
broken shift fork with posi-lock type setup? dave_dj1 YJ Wrangler Technical Forum 6 04-26-2009 08:48 PM
Front disconnect fork question bigh20rnr YJ Wrangler Technical Forum 2 02-02-2008 10:12 PM
Front Shift Fork worn? Greatwhite007 YJ Wrangler Technical Forum 3 01-24-2007 10:05 PM
front axle shift fork broke Tonka YJ Wrangler Technical Forum 2 06-21-2001 03:29 AM
