Front axle centering SOA - JeepForum.com
post #1 of 5 Old 01-26-2012, 07:26 AM Thread Starter
mikes88yj
Bought an 88 Wrangler that PO did an SOA on, was wondering if there is a way to tell if the front and rear axles are centered from left to right? All old spring perches and shock mounts were cut off. Just double checking everything that was done before I start body work. Also, no alignment shop around me will touch the thing with 35's on it.
Front axle is a dana 30 rear is an xj dana 44
Thanks,
Mike
mikes88yj is offline
post #2 of 5 Old 01-26-2012, 11:04 AM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
One way is to use a plumb bob along the sides of the frame above the axles & measure where the string is to a point on the axle (EG: from where the string falls to the top of a knuckle) and compare side to side measurements to see if they are equal.
Check this link out for a basic toe-in alignment. Super simple & free since all you can do on a YJ is toe-in.
http://www.4x4xplor.com/alignment.html
Joe Dillard is offline
post #3 of 5 Old 01-26-2012, 12:22 PM
ssyj94
To see if its square with the frame you can also measure from center of driver balljoint to the passenger framerail and then pass balljoint to driver frame. Basically measureing a big X underneath.
My build:
ssyj94 is offline
post #4 of 5 Old 01-26-2012, 12:43 PM
zman
Pretty hard to screw up the centering of the axels. Even if they were off a 1/4" it would be hardly be noticable. I would be more concerned with DL angles and caster.
zman
1995 YJ on 40's * 2002 TJ on 37's * 2003 TJ on 33's * 2011 WK Larado X w Hemi
zman is offline
post #5 of 5 Old 01-26-2012, 01:03 PM Thread Starter
mikes88yj
Thanks will try with the plumb bob and will also measure to verify.
Pinion angles look to be alright about 2-3 degrees from sye and set at about 7 degrees caster angle in the front. I just wanted to check that it tracks right.
Thanks,
Mike
Centering my front axle on TJ 300whisper TJ Wrangler Technical Forum 9 03-04-2010 08:33 PM
centering my front axle. bow_hunter8 TJ Wrangler Technical Forum 9 02-02-2010 09:54 PM
Front Axle Centering Question tangofox007 TJ Wrangler Technical Forum 1 08-08-2008 02:48 PM
Centering Front Axle... thejafe TJ Wrangler Technical Forum 5 01-02-2006 03:42 PM
centering front axle ces001 TJ Wrangler Technical Forum 1 06-14-2004 11:48 AM
