Freshening Up A 4.0 Before Swap - Page 3 - JeepForum.com
post #31 of 54 Old 03-28-2013, 01:22 PM Thread Starter
voz
Help,
Please before this item gets sold..
VOZ™
voz is offline
post #32 of 54 Old 03-28-2013, 01:35 PM
Que89YJ
I am not sure but you can go online to any of the parts places and see if they have the same part number.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #33 of 54 Old 04-16-2013, 09:13 AM Thread Starter
voz
VOZ™
voz is offline
post #34 of 54 Old 04-16-2013, 09:15 AM Thread Starter
voz
Just a few pics of what I got done last weekend...
Cleaning these parts at a B I T C H !!!
It has been a slow process, but with my friends out and about on their YJ's, I get motivated
VOZ™
voz is offline
post #35 of 54 Old 05-13-2013, 09:50 AM Thread Starter
voz
damn,
this build is a slow process....
VOZ™
voz is offline
post #36 of 54 Old 05-13-2013, 12:41 PM
idaholtby
The 2.5L fuel lines will be too short for the 4.0L fuel rail. When I swapped my 2.5L for the current 4.0L I had to use a Fuel injector line repair kit that allowed me to splice into the original 2.5L lines which then allowed the extra length needed to reach the 4.0L fuel rail connections. The fuel rail connections on the 4.0L are two cylinders further forward of where they are on the 2.5L.
idaholtby is offline
post #37 of 54 Old 05-13-2013, 01:28 PM Thread Starter
voz
Thanks,
I'm still looking for the lines, will go to the local pullurown part soon...
VOZ™
voz is offline
post #38 of 54 Old 05-13-2013, 01:34 PM
idaholtby
Originally Posted by voz View Post
Thanks,
Well if need be, the 2.5L lines can be made to work if you can't find the 4.0L lines, just that you would have to splice in the repair kit to lengthen them. Just trying to give you all options available. If IIRC, the cost for such a kit was around $20 bucks. Just don't remember if that was per line or covered both. Most auto part stores carry these kits. It is kind of a B to splice into the nylon lines, but is doable if you can't source the proper 4.0L lines.
post #39 of 54 Old 05-13-2013, 02:18 PM Thread Starter
voz
Very good info indeed!
I still have time,
I gave myself until 8/1/13 to be finished with this swap/build
I am also eyeing one on ebay...
VOZ™
voz is offline
post #40 of 54 Old 05-20-2013, 09:15 PM Thread Starter
voz
I did not remove head, after seeing how clean/ sludge free engine looked after removing valve cover and oil pan.
I still need a few odds and ends, oil pressure sending unit & dip stick tube ( i bent it )
still have to get transmission looked at. also need a 23 spline 231
VOZ™
voz is offline
post #41 of 54 Old 05-21-2013, 01:28 PM
Siva283
You can swap the input shaft in your current 231 to the 23 spline if you can find an input shaft for the right price. It would probably be alot cheaper than getting another 231.
Ask me how I know...
Siva283 is offline
post #42 of 54 Old 05-22-2013, 02:05 AM
billybooster2
1983 CJ8
If you change tranny from manual to auto or vice versa, your ecm MAY need to be changed / played with to bypass a neutral safety switch...just a thought,,
billybooster2 is offline
post #43 of 54 Old 05-22-2013, 04:33 AM Thread Starter
voz
I have ECM from donor rig.
I have a 21 spline, but it needs rebuilding. Hopefully I can find a shaft fairly cheap.
VOZ™
voz is offline
post #44 of 54 Old 06-08-2013, 06:00 PM Thread Starter
voz
I finally unbolted everything off the 4.2 so hopefully tomorrow I can pull it out. I have to then sand and paint the engine bay before 4.0 goes in..
One question, what do I. Need to save from 4.2, ba10 or NP 207 that need to go to my 4.0, Tf999 swap?
I would like to sell 4.2, ba10 & np207. I need the money to pick up odds and ends that I know I will run into with this swap.
VOZ™
voz is offline
post #45 of 54 Old 06-20-2013, 12:03 PM Thread Starter
voz
Any thoughts on which oil cooler to use with my OEM radiator?
I'm looking for ease of installment/placement
VOZ™
voz is offline
