Fresh tune still hard starting - JeepForum.com
post #1 of 4 Old 05-12-2014, 06:50 AM Thread Starter
mzootie
Ok I replaced plugs, wires, cap and rotor. Fuel pressure held pressure for 30 min at rail so no fuel problem. Jeep runs ok after starting. Hard starting occurs no matter hot/cold or when. It does eventually start every time. Thinking coil, CPS or ECU. Could run a little smoother but most folks would think it runs fine. What is the most probable thing to check next. Also jeep is 91 and only has 50K and did a lot of sitting along the way.
mzootie is offline
post #2 of 4 Old 05-12-2014, 07:51 AM
Delawdude
How long has it been sitting--- could be bad gas if it's been sitting a long time. Drain (syphon) and add new.
May also want to check your timing--read this thread
http://www.jeepforum.com/forum/f12/timing-4-0l-508405/
Delawdude is offline
post #3 of 4 Old 05-12-2014, 08:39 AM
Que89YJ
Always start with codes. Check your fault codes and post what you get:
http://www.jeepforum.com/forum/f12/h...codes-1257145/
Last tune up?
Dont guess, troubleshoot. Fuel or spark. Its holding pressure but it is possible that its still a fuel issue. Try some starting fluid and see if it cranks. Check your spark and see if it is blue.
Que89YJ is offline
post #4 of 4 Old 05-12-2014, 11:17 AM
Old4X
1990 CJ7
Last tune up?
You really need a proper spark tester with today's ignitions. Only about 6 bucks at the auto parts store and is calibrated to quickly ID a weak spark vs a strong spark.
Also a proper fuel pressure gauge. It may hold pressure, but how much pressure?
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
