Freezing my arse off... - JeepForum.com
post #1 of 3 Old 02-14-2002, 07:02 PM Thread Starter
mikeyjph
My Wrangler's air vents are stuck open, the lever on the dash will go to off or defrost, but in the heat position it just snaps back to the vent position, which is always on. Anybody had this happen before? I have an 89 with no ac. Thanks for your help
mikeyjph is offline
post #2 of 3 Old 02-15-2002, 04:53 PM
Big92Jeep
Look under the dash on the passenger side. You can see the simple lever that controls heat/air control. If your cable is binded up between your dash controls and this lever you can do it manually until you get the cable fixed.
~RýCK
2008 Unlimited Rubicon
"The weather is here, I wish you were beautiful"
Big92Jeep is offline
post #3 of 3 Old 02-16-2002, 07:32 PM
FLHT_FXRS_YJ
FLHT_FXRS_YJ's Avatar
I've got the same problem in my 89' YJ. A roll of silver duct tape solved the problem.
89' YJ - 4.2 - NV4500 - NP231w/sye - 1" Body Lift - 2 1/2" Rancho Suspension Lift - 31" Firestone MTR - AR Outlaw II - Tomken Bumpers F & R - Warn 8000 front - Warn 6000 rec. mount rear - FlowFit Seats - Tom Woods Rear & Custom 2" front driveshafts
FLHT_FXRS_YJ is offline
help freezing my tail off!!! bigboss408 YJ Wrangler Technical Forum 8 12-06-2009 06:23 PM
no heat...I'm freezing. BostonJosh19 TJ Wrangler Technical Forum 21 01-22-2007 07:35 PM
My New Big Arse Rebuild Project ONX TJ Wrangler Technical Forum 17 12-22-2006 09:05 PM
I want to be freezing in the summer.... austin mclean YJ Wrangler Technical Forum 4 05-22-2001 10:30 AM
