Free 8.8!! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Free 8.8!!
Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri2007-2016 Jeep JKU 4" X-series suspension lift **dea
Unread 03-08-2008, 03:31 PM   #1
dand3053
Free 8.8!!
My dad is swapping an engine out of one Exploder and into another at the place where he works and then junking the rest of the truck. I mentioned the 8.8 Rear option for my rear axle project and he said I could HAVE it.
The Exploder is a 2000 2WD.
Here is what I dont know: the gear ratio (most likely 3.55 or 3.73-----both are what im looking for--more towards the 3.73 tho), whether it has discs, and/or limited slip.
I want to know if anyone has any info on the rear of these trucks from 2x4s and anything i should watch out for ---meaning should i bother taking it?
dand3053 is offline   Reply With Quote Quick reply to this message
Unread 03-08-2008, 04:09 PM   #2
builder
It will be disc and if your lucky it wont have the L-slip. But that is one good price.
95 YJ
builder is offline   Reply With Quote Quick reply to this message
Unread 03-08-2008, 04:10 PM   #3
builder
95 YJ
Unread 03-08-2008, 04:18 PM   #4
Tkamplin
Why lucky without the limited slip?
Tkamplin is offline   Reply With Quote Quick reply to this message
Unread 03-08-2008, 04:22 PM   #5
The_Duke
Because you would have to get an open carrier if you wanted to use a locker in it.
If you have no plans for locking it, the LS will be fine, but if you do plan on running a locker, you will need to buy a new carrier.
'95 YJ, 4.0L I6, 4" Rough Country Lift, Warn Floating Axle, M.O.R.E. Boomerang Shackles, 33x12.5 Kuhmo M/Ts, 9500 LB Warn HS9500i with synthetic line and 7500 LB Winch, Hi-Lift, KC Daylighters, OBA, K&N High Performance Intake System, Tube Steps, and an Aussie up front.
1998 XJ Limited Sport - Stock....for now.
The_Duke is offline   Reply With Quote Quick reply to this message
Unread 03-08-2008, 04:26 PM   #6
builder
I just dont like them. Stock limited slips are normally worn out by 50,000 miles. And it rules out the cheap lunch box lockers since theres no carrier.
95 YJ
Unread 03-08-2008, 07:38 PM   #7
dand3053
Great...thanks....now i just hope there isnt a Ltd Slip.
Unread 03-08-2008, 08:45 PM   #8
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
for the price, i wouldnt worry about the lsd or no lsd.
you will be far ahead of the rest of us that had to pay for an 8.8.
well done!
martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
http://www.jeepforum.com/forum/f12/swap-offically-underway-324622/
leftlanetruckin is offline   Reply With Quote Quick reply to this message
Unread 03-08-2008, 09:56 PM   #9
dand3053
now i have to change the future mods to 8.8 instead of Dana44 .
I've already found a ton of info for making it work, i have a pinion angle tool and new spring mounts and shock mounts.
I'm assuming i can reuse the explorer spring plates?
Unread 03-08-2008, 10:32 PM   #10
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Yep, you can reuse them but you may want to trim away all the unnecessary portion of those spring plates.
For those who don't know - here's what the stock F8.8 spring plates look like. They incorporate the lower shock mounts into them which would probably be useless unless you were redoing the uppers to utilize the lowers.
IMHO, they hang too low and would be rock magnets, plus stock upper mounts wouldn't work since the angles would be all wrong.
Joe Dillard is offline   Reply With Quote Quick reply to this message
Unread 03-09-2008, 09:56 AM   #11
Richmond88yj
Eat, Sleep, Jeep
Richmond88yj's Avatar
Are you saying the stock 8.8 perches can be used as they are? no re-welding them?
Richmond88yj is offline   Reply With Quote Quick reply to this message
Unread 03-09-2008, 10:03 AM   #12
timatoe
I know at least one person on here (not in this thread though) said they did just that. They said they had to pull the springs in a bit. But, I'm pretty sure Joe's just refering to the spring/U-bolt plates themselves.
timatoe is offline   Reply With Quote Quick reply to this message
Unread 03-09-2008, 10:31 AM   #13
mississippi_xj
the spring perches will be about .5" off. The shock mounts *do* work.
I ran my shocks on those mounts for ~ 1.5 years.
-scotty
Shopping for a WJ to replace my DD Land Rover, Former TJ/YJ/XJ/WRX Builder...
Contribute to my YJ spring rate info thread!
mississippi_xj is offline   Reply With Quote Quick reply to this message
Unread 03-09-2008, 10:53 AM   #14
goatboy
If it is limited slip, I think yer ahead of the game...when I install my 8.8, I do want LS, and I'll go with an Aussie Locker in the front end, and that should get me the performance I'm lookin' for...a buddy of mine has a 1993 Explorer 4X4 with LS in the rear, is VERY happy with how it performs off road...
goatboy is offline   Reply With Quote Quick reply to this message
Unread 03-09-2008, 11:10 AM   #15
ErikJordan
Pimp Hand
ErikJordan's Avatar
this is "true" but not optimal.
i ran mine like this for a while.
you really need 4" lift or so to be able to angle the springs in enough to make it work.
you will be much better off to cut the perches and reweld in the correct location with the correct pinion angle.
___________________________________________
What is all of this talk of Savvily designed products?
ErikJordan is offline   Reply With Quote Quick reply to this message
