Freaking doors! - JeepForum.com
post #1 of 6 Old 09-06-2011, 01:04 PM Thread Starter
paleface
Freaking doors!
Ok I am quite sure it's been posted a million times, I have read a million post and now I am more confused than ever! I have a 95 wrangler with steel half doors, bought a factory hardtop to use, I just purchased some full steel doors for it. I put them on and they don't align with my door strikers. I moved the strikers as high as I could and no luck. Wth? I am quite sure this is an easy fix, but I just don't know that much about Jeeps. Please help with this!
paleface is offline
post #2 of 6 Old 09-06-2011, 01:11 PM
brk913
First put your striker back where it was, then loosen the hinges on the outside of the door (2 people come in handy here) adjust door to position you need, tighten hinge bolts, done...easier sounding than it actually is. When I had to do mine I loosened the hinges had my friend help me position and shut the door then tightened the hinges....
brk913 is offline
post #3 of 6 Old 09-06-2011, 01:16 PM Thread Starter
paleface
Ok thanks I will give it a try. I really appreciate it. I feel like an idiot having to ask such a stupid question. Thanks again.
paleface is offline
post #4 of 6 Old 09-06-2011, 01:20 PM
jmmorgan82
2009 JK Wrangler
I loosened my hinges and shimmed up around the door frame using wood shims and some cardboard. Once everything looked satisfactory, I locked 'em down.
jmmorgan82 is offline
post #5 of 6 Old 09-06-2011, 02:20 PM
tdewit
DO NOT STRIP THE TORX BOLTS!!!
Get an impact to loosen the bolts. Do not attemp loosening them without it, otherwise you will strip 1 or 2 heads.
tdewit is offline
post #6 of 6 Old 09-16-2011, 12:52 AM Thread Starter
paleface
Worked like a charm, it was super easy. Thanks alot guys!
paleface is offline
align , door latch , full doors , hardtop , steel doors
Freaking out??? bunyan52 TJ Wrangler Technical Forum 12 05-16-2010 07:39 PM
Freaking Zippers! TeamFATBOY TJ Wrangler Technical Forum 11 07-12-2009 07:04 PM
freaking rearview mirror! DFW_Dave YJ Wrangler Technical Forum 13 05-08-2007 09:20 PM
freaking oil pressure blake989 YJ Wrangler Technical Forum 1 11-17-2005 10:33 AM
Hardtop's freaking me out moonlight TJ Wrangler Technical Forum 4 10-06-2004 03:57 PM
