Frameless soft top? - Page 2 - JeepForum.com
post #16 of 30 Old 07-11-2013, 11:06 PM Thread Starter
SurferJ
Originally Posted by WidowYj91
The rampage looks so much better, I hate how the softopper looks loose.
Agreed. But like I said. Rampage only makes it for the YJ with half doors.
SurferJ is offline
post #17 of 30 Old 07-12-2013, 06:56 AM
Relicmoto
Flame shields up, I mean no disrespect. I was under the impression that the difference between tj and yj soft tops lie in the bow configuration. How the bows and frames are designed, and how the fabric attaches to the bows. Aren't yj's and tj's essentially the same dimensions? I know there has to be a difference, but as long as the yj has the full family bars I don't see why one would not work on the other aside from the mounting method above the windshield.
Relicmoto is offline
post #18 of 30 Old 07-12-2013, 07:08 AM
johnboy68
HIP2BSQR
johnboy68's Avatar
The other big difference is between the stock soft uppers on the half doors. The stock YJ uppers have a square corner and the stock TJ uppers have a rounded corner. The Bestop Super top replaces the soft uppers for the YJ and has the rounded corners. So, if you get a Softopper, you need to modify the TJ uppers to work on your YJ half doors or already have a Super top.
-John-
johnboy68 is offline
post #19 of 30 Old 07-12-2013, 08:14 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
The other other big difference is that the TJ comes with 'built in' (sort of) one piece door surrounds, while the YJ's door surrounds are part of the front soft top hoop. Take the soft top and hoops off a TJ, the surrounds are still there. Take the soft top and hoops off a YJ and surrounds are gone. This makes implementing any YJ soft top a bigger project.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #20 of 30 Old 07-12-2013, 08:31 AM
zte87
GIVE IT THE ONION
zte87's Avatar
The soft topper is also made out off a lot more durable material just saying.........
zte87 is offline
post #21 of 30 Old 07-12-2013, 08:34 AM
HaskiE
HaskiE's Avatar
huh?
#theneverendingaxe
HaskiE is offline
post #22 of 30 Old 07-12-2013, 08:40 AM
JeeperDon
JeeperDon's Avatar
Originally Posted by HaskiE View Post
huh?
TJ door surrounds... not attached to anything but the tub and roll bar.
YJ door surrounds... part of the soft top hoop assembly.
Web Admin for
post #23 of 30 Old 07-12-2013, 09:03 AM
HaskiE
HaskiE's Avatar
ohhhhhhhhhhhhhhhhhhhhhhhh
gotcha I thought you meant where the tj door surrounds mounted...
JP did an article that put a TJ top on a YJ, but swapped in the TJ roll bar too. Maybe if you did the TJ roll bar swap you could run a rampage frameless on a yj?
#theneverendingaxe
HaskiE is offline
post #24 of 30 Old 07-12-2013, 10:01 AM Thread Starter
SurferJ
is that YJ frame the OEM soft top frame? ive had 2 soft tops and never had bows like that. the rear bows always mount to the front bows on tops ive had.
SurferJ is offline
post #25 of 30 Old 07-12-2013, 10:52 AM
HaskiE
HaskiE's Avatar
sounds like you have a supertop... easier to put up and down than the stock yj top imo
this kinda sorts out which top is what
linky: http://www.etrailer.com/faq-jeep-soft-top-hardware.aspx
#theneverendingaxe
HaskiE is offline
post #26 of 30 Old 07-12-2013, 11:00 AM Thread Starter
SurferJ
Nice link. Yeah both tops were super tops with the bestop frame. I think the Bestop frame sucks, that oem frame looks god awful.
I may try and sell this super top in the spring and go frameless. I have conflicting ideas on what I want. Cheap and good quality are hard to combine lol
SurferJ is offline
post #27 of 30 Old 07-12-2013, 05:29 PM
superj
That is very true .
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #28 of 30 Old 10-20-2014, 11:31 AM
amp713
Bringing this back from the dead as im debating going frameless after my weekend in moab.... Any companies came out with one for full steel doors in the last year? If not ill just run my hard top through winter and buy the softtopper in spring i think.
I like my YJ how I like my whiskey, on the rocks with just a touch of color!
amp713 is offline
post #29 of 30 Old 10-20-2014, 12:00 PM
AZdEvilYJ
Softtopper and Bestop Supertop are your only options for a soft top that works with full hard doors.
'95 YJ 2.5L
March '15 YJ of the Month!
Exiled Offroad - Arizona
My Build Thread
AZdEvilYJ is online now
post #30 of 30 Old 10-20-2014, 12:51 PM
amp713
Perfect! Guess ill be getting a softtopper haha
amp713 is offline
