Frame shackles bushing getting destroyed - JeepForum.com
post #1 of 20 Old 09-16-2013, 06:02 AM Thread Starter
bogleparsons
I seem to have an issue destroying bushing in my grease-able boomerang shackles. The bushings that go in the frame mount aren't lasting long at all.
I torqued them to 50ft/lbs but seem to destroy them in just a few outings.
Any insight would be great. Maybe I have the wrong size bushing because the ones I used are tapered like a mushroom but the lower (spring) side of the shackle looks like a more flat bushing.
I will post pics this afternoon.
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline
post #2 of 20 Old 09-16-2013, 10:59 AM
booboowv77
Are they rubber or poly? My rubber ones only lasted about 3 months, but my poly ones have been going for about 6 months now and are just fine.
GOOGLE IS YOUR FRIEND!!!
Just my toy!
89 YJ, Fresh 4.0, ax15, SOA w/410's, and about a million other things! :)
Built not Bought #759
booboowv77 is offline
post #3 of 20 Old 09-16-2013, 11:20 AM Thread Starter
bogleparsons
To be honest, I don't know.
I will definitely buy poly after I use these last 2 i have laying around.
post #4 of 20 Old 09-16-2013, 11:36 AM
booboowv77
poly is normally colored (red) rubber is normally black.
Just my toy!
post #5 of 20 Old 09-16-2013, 11:44 AM Thread Starter
bogleparsons
ah, all mine are black.
post #6 of 20 Old 09-16-2013, 12:43 PM
Sparrows
How long is the inner sleeve? I believe it should be slightly longer than the bushing on either side and the shackles should contact that and not so much the bushing.
Cheers
June '13 YJOTM
Sparrows is offline
post #7 of 20 Old 09-16-2013, 01:19 PM
squarelite
My poly bushings are black. Poly comes in all sorts of colors
squarelite is offline
post #8 of 20 Old 09-16-2013, 01:41 PM
superj
Cheers
i noticed this when i was installing mine a few years ago. i bet this is the reason yours are wearing out, probably rubbing as the suspension droops and lifts
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #9 of 20 Old 09-17-2013, 03:58 AM Thread Starter
bogleparsons
You guys are right my sleeve is like 1/2" from the end on each side. If this is the reason great catch!
Weird I bought these shackles last year and they came with all the hardware.
post #10 of 20 Old 09-17-2013, 11:44 AM
Sparrows
Yup, there's your problem! They should stick out maybe a 1/16" on each side. The shackles should ride on the sleeve. The bushing is there to isolate the movement from the frame and not for the shackles to rest on.
Cheers
June '13 YJOTM
Sparrows is offline
post #11 of 20 Old 09-17-2013, 04:53 PM
instg8tor
I could be wrong, but its my understanding that rubber bushings don't have the metal sleeve past the rubber - only the poly's have a longer sleeve
'91 Renegade - Waggy 44/20 (F/R Aussie) SOA, E350 MC, York OBA, Custom F/R bumpers
instg8tor is offline
post #12 of 20 Old 09-17-2013, 10:40 PM
Dake
Dake's Avatar
1/16 that sounds like a lot. I may have to revisit my bushings.
Waiting on my Rough Country lift to sag!
Dake is offline
post #13 of 20 Old 09-18-2013, 12:39 AM
Sparrows
By 1/16" I mean just a hair. Just enough to keep the shackle from riding on the bushing....
Cheers
June '13 YJOTM
Sparrows is offline
post #14 of 20 Old 09-18-2013, 11:21 AM
Pawjob
WOW never knew...Mine stuck out just a 1/16th but my buddy who has an XJ told me that the metal sleeve shouldnt stick out or be flush with the bushing. Thats why I was having front end drivablity issues. So I ended up cutting the metal sleave so its inside the bushing 1/16 on each side.
1994 Grand Cherokee Daily Driver
7" IRO Long arm, 35" Cooper Discrover STT. And more
1993 Wrangler, Rock Smashing Jeep, and November 2012 YJOTM...
1.5" SOA, Stak 3 speed Tcase, 37" Swamper M16's...ALOTS of extras
Pawjob is offline
post #15 of 20 Old 09-18-2013, 11:27 AM
Sparrows
I can't seem to find it but Anti had a nifty little paint mock up showing the proper set up....maybe he can chime in and give you a little visual
Cheers
June '13 YJOTM
Sparrows is offline
