-   -   Frame shackles bushing getting destroyed (http://www.jeepforum.com/forum/f12/frame-shackles-bushing-getting-destroyed-1591065/)
bogleparsons 09-16-2013 07:02 AM
I seem to have an issue destroying bushing in my grease-able boomerang shackles. The bushings that go in the frame mount aren't lasting long at all.
I torqued them to 50ft/lbs but seem to destroy them in just a few outings.
Any insight would be great. Maybe I have the wrong size bushing because the ones I used are tapered like a mushroom but the lower (spring) side of the shackle looks like a more flat bushing.
I will post pics this afternoon.
booboowv77 09-16-2013 11:59 AM
Are they rubber or poly? My rubber ones only lasted about 3 months, but my poly ones have been going for about 6 months now and are just fine.
bogleparsons 09-16-2013 12:20 PM
To be honest, I don't know.
I will definitely buy poly after I use these last 2 i have laying around.
booboowv77 09-16-2013 12:36 PM
poly is normally colored (red) rubber is normally black.
bogleparsons 09-16-2013 12:44 PM
ah, all mine are black.
Sparrows 09-16-2013 01:43 PM
How long is the inner sleeve? I believe it should be slightly longer than the bushing on either side and the shackles should contact that and not so much the bushing.
Cheers
squarelite 09-16-2013 02:19 PM
My poly bushings are black. Poly comes in all sorts of colors
superj 09-16-2013 02:41 PM
Cheers
i noticed this when i was installing mine a few years ago. i bet this is the reason yours are wearing out, probably rubbing as the suspension droops and lifts
bogleparsons 09-17-2013 04:58 AM
You guys are right my sleeve is like 1/2" from the end on each side. If this is the reason great catch!
Weird I bought these shackles last year and they came with all the hardware.
Sparrows 09-17-2013 12:44 PM
Yup, there's your problem! They should stick out maybe a 1/16" on each side. The shackles should ride on the sleeve. The bushing is there to isolate the movement from the frame and not for the shackles to rest on.
Cheers
instg8tor 09-17-2013 05:53 PM
I could be wrong, but its my understanding that rubber bushings don't have the metal sleeve past the rubber - only the poly's have a longer sleeve
Dake 09-17-2013 11:40 PM
1/16 that sounds like a lot. I may have to revisit my bushings.
Sparrows 09-18-2013 01:39 AM
By 1/16" I mean just a hair. Just enough to keep the shackle from riding on the bushing....
Cheers
Pawjob 09-18-2013 12:21 PM
WOW never knew...Mine stuck out just a 1/16th but my buddy who has an XJ told me that the metal sleeve shouldnt stick out or be flush with the bushing. Thats why I was having front end drivablity issues. So I ended up cutting the metal sleave so its inside the bushing 1/16 on each side.
Sparrows 09-18-2013 12:27 PM
I can't seem to find it but Anti had a nifty little paint mock up showing the proper set up....maybe he can chime in and give you a little visual :)
Cheers
The time now is 03:20 PM.
