Frame repair; cost, issues, questions - JeepForum.com
post #1 of 14 Old 10-29-2009, 11:14 AM Thread Starter
ZeroGravity
So I found a rust hole between the tabs of my rear upper shock mounts. It's probably 1/4" at the moment (don't wanna dig out more).
Has anyone had this done professionally? How much did they charge and how long (days, weeks, months, etc) did it take from start to finish?
Is this repair going to require removing the tub from the frame? Because if it get's to that, I figure that I might as well simply replace the frame.
Do you think this is something a non-experienced welder could do? My buddy has a welder he just purchased but I've never welded before and the last thing I want to happen is to take my Jeep apart, cut apart the frame, and not be able to get it back together.
In fact, It doesn't even sound that difficult to weld it, it's just in a very poor location as far as working-space goes.
91 YJ
98 XJ
2 door love
The U.S. Army vaguely envisioned something bigger than a motorcycle, smaller than a truck, and undaunted by the most difficult terrain.
ZeroGravity is offline
post #2 of 14 Old 10-29-2009, 11:37 AM
yjjeepster
Any pics? I live in western ma and I have done frame repair on mine. Mine was rotted just behind the rear spring shackle. I fixed that without taking off the body. Where are you located? Maybe I can help.
95 yj 4.0 4" rc 33's. 8.8 rr, lockrights with 4.88's front and rear. warn xd9000i. tag, warn, hella, dynomax, optima
yjjeepster is offline
post #3 of 14 Old 10-29-2009, 11:39 AM
autoboy454
Sorry to thread-jack (I also have a frame lying around with the same problem) buy yjjeepster where in Western MA are you located? I'm in hatfield.
EDIT, also I have some welding experience and could probably also lend you a hand!
autoboy454 is offline
post #4 of 14 Old 10-29-2009, 11:45 AM
yjjeepster
I'm in greenfield. I work right down the road from you. I'm the manager at napa on deerfield st.
post #5 of 14 Old 10-29-2009, 11:45 AM
jbolty
jbolty's Avatar
like this one?
http://www.jeepforum.com/forum/f12/f...estion-431601/
I cut out the bad part and welded in 3/16 plate on three sides, plus a piece on the inside.
not a hard job but before doing it make sure your weling buddy can lay down a good bead with good penetration.
jbolty is offline
post #6 of 14 Old 10-29-2009, 11:51 AM
linemen339
Don't know where in Ma you are but Kent's welding is the best around where I live. He works on YJ frames a few times a week.
Kent's Welding
3039 Cranberry Hwy, East Wareham, MA‎ - (508) 295-3791‎
linemen339 is offline
post #7 of 14 Old 10-29-2009, 08:32 PM Thread Starter
ZeroGravity
Originally Posted by jbolty View Post
like this one?
Similar, but on the other side. It could be on both sides.
But it's right on the inside edge so I would probably need to cut it to the backside of the frame.
I like a little north of Boston, MA.
91 YJ
98 XJ
2 door love
post #8 of 14 Old 09-15-2013, 12:56 PM
succubus26
hey zerogravity
where did you end up having the work done? were you happy with the job/cost? am looking at needing some welding done on my TJ now also. thanks!
succubus26 is offline
post #9 of 14 Old 09-15-2013, 05:38 PM
trwedgn
I just finished repairing the same area on my 88. It's easy to see the holes in the top of the frame, but what you can't see until you take the old mounts off, is the holes on the inside of the frame. Whoever designed those mounts must have owned a body shop. What I did to repair it was to build new shock hangers using 8" of 3x2.5x3/16 angle and a piece of 1 1/4" round bar. One 2.5" leg of the angle goes on top and the other goes on the inside of the from. I used a piece of 3x3/16 flat bar on the outside of the frame, mounted high enough to weld it to the angle bar. In addition to welding the entire perimeter, I drilled holes and plug welded both pieces. I had the rear end out, so access wasn't that bad. The drivers side was a little tricky with the gas and brake lines in the way.
trwedgn is offline
post #10 of 14 Old 09-15-2013, 06:04 PM
NHfireLJ
NHfireLJ's Avatar
I did my own. Seacoast NH
No, can be done with tub on. fuel line can get in the way and helps to move them
Yes, with some practice. if it fails a shock mount is not a catastrophic failure, so it would be a good test of your skills
Yeah sucks in that spot
AUDREY...95 YJ UNLIMITED
SOLD
YJOTM FEB 2013
NHfireLJ is online now
post #11 of 14 Old 09-15-2013, 07:49 PM
alc60560
auto rust tech has a lot of frame repair parts. easy to work with.
alc60560 is offline
post #12 of 14 Old 09-15-2013, 08:12 PM
NHfireLJ
NHfireLJ's Avatar
Not for the shock mount
SOLD
YJOTM FEB 2013
post #13 of 14 Old 09-16-2013, 07:31 AM
Kdeome
I believe I bought my new shock mounts from 4wd or Morris. Like $20 a piece.
A little bit of grinding and I welded mine on no problem, but I had my tub off anyways.
Kdeome is offline
post #14 of 14 Old 09-18-2013, 04:53 PM
alc60560
Yes they do have them for left and right. Have used them.
alc60560 is offline
Mirror Dent? What was your repair cost? wesley8808 JK Wrangler Technical Forum 4 09-05-2007 12:28 PM
4 cyl cost $2728 to repair Zennashton TJ Wrangler Technical Forum 8 06-24-2007 07:20 PM
cost of repair,ax-5 2cjs YJ Wrangler Technical Forum 12 12-13-2006 05:41 PM
? about body damage repair cost ylojelo YJ Wrangler Technical Forum 7 04-18-2005 08:19 PM
Body damage repair/cost question Freakshow TJ Wrangler Technical Forum 5 03-30-2005 05:26 PM
