Frame repair - JeepForum.com
post #1 of 15 Old 06-30-2007, 01:59 PM Thread Starter
justpicaname
Frame repair
I have 2 bad spots on my 94 frame, front drivers side (at stearing box) and rear passanger side (at shackle). It's really bad (can post pics if needed) leafs might rip off frame soon.
I have to options to cut out the rotten metal and make a template cut a patch and weld it in, or I can just put more metal on top of the old stuff. I need to repair the face and bottom near the stearing box. And the rear has a divit in the frame where the shackle bolt goes though, that spot I will have to cut the old steel out for sure.
Now does anyone know the welding procedure for welding a frame? ie what rod what type of joint & gap. Also what grade steel do I use, and what thickness of steel?
I saw a frame reinforsment plate for gm trucks for there steering box but can't find one for a YJ, anyone ever see one? That might work for me.
Thanks
justpicaname is offline
post #2 of 15 Old 06-30-2007, 02:28 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
cut out all the bad steel......
i used 1/8" flat stock on my old frame, worked fine.
2 1/2 flat will cover the top and bottom of the frame, and you can buy the frame repair section for the frame rail by the steering box, found mine on ebay a year or so ago, may wanna look there..
i just mig'd the sections on.....hell i'm a truck driver, if it isn't in the welder already, it dont get used....
regular .30 wire and shielding gas worked fine for me..
martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #3 of 15 Old 06-30-2007, 03:37 PM
noodle9
I have a 94 and I cut the bottom of the frame off and slid in some 2x2 with 1/8" wall and welded to the old metal after cutting out the bad parts. It is holding up great. Good luck.
noodle9 is offline
post #4 of 15 Old 06-30-2007, 05:06 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
If things look anything like this (this is not my YJ)....I'd cut the entire area out & replace it.
Joe Dillard is offline
post #5 of 15 Old 06-30-2007, 06:20 PM Thread Starter
justpicaname
Ooch, mines not that bad yet. But wouldn't take long.
Thanks leftlanetruckin I'll check ebay. What did you do with the vert welds, fishplate them?
post #6 of 15 Old 07-01-2007, 01:39 PM
leftlanetruckin
XJ on 37's
yeppers!
martin
post #7 of 15 Old 07-01-2007, 07:45 PM
doug_1994
doug_1994's Avatar
Here's a great write-up.
http://www.jeepforum.com/forum/showt...t=frame+repair
Doug
Wise men speak because they have something to say;
Fools because they have to say something.
Plato
doug_1994 is offline
post #8 of 15 Old 07-04-2007, 09:04 AM Thread Starter
justpicaname
one more thing, on the back of the frame, where the rear shackle bolt goes through. Dose the steel need to have that indent, it's been done with some special countersink drillbit i guees. I think its there to add strenght to the area.
If this needs to be done what the easyest way to do it, or any alternatives.
Thanks again
post #9 of 15 Old 07-04-2007, 09:10 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
It doesn't need the indent. If you look at the write up posted above by doug, sentinal does not creat that indent. Just put a new piece of tubing in there and it will be plenty strong.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #10 of 15 Old 07-04-2007, 09:18 AM Thread Starter
justpicaname
ok, cool. But will this repair pass a safty inspection. Not sure who is more strickt U.S or Canada? I will be moving about a month after I do the repair, and will probbably have to change insurance, and get a safty check done. I hope I'll be able to pass.
post #11 of 15 Old 07-04-2007, 09:23 AM
rustywrangler
As long as you do it right and don't cut corners it should. Not shure what the canada regs are on it.
post #12 of 15 Old 07-04-2007, 10:35 AM
leftlanetruckin
XJ on 37's
done right, they wouldn't notice the repair for what it is!
at the most, it would look like some reinforcement for the rear of the frame...
martin
post #13 of 15 Old 07-04-2007, 01:47 PM
ebproseller
This is what you see !!!!!!!
I had the same thing as you, I've fix it and 1 year later I've found some other big holes, near the rear shock mount, beside the fuel filter ......
So i've baught another YJ with a good frame and swap it !
ebproseller is offline
post #14 of 15 Old 05-19-2008, 09:34 AM Thread Starter
justpicaname
I got around to fixing my frame, I must say it wasn't as hard as I thought.
The jeep handles alot better now, dosn't feel like the wheels are going to jump off when I turn hard now!
Hear are some pics of the project
http://i78.photobucket.com/albums/j8...h2008006-1.jpg
after I cut out the bad stuff
http://i78.photobucket.com/albums/j8...rch2008008.jpg
even the inside was cracked bad
sorry guys can't post my pics anymore. (my post count got reset!)
http://i78.photobucket.com/albums/j8...rch2008016.jpg
starting the welding
http://i78.photobucket.com/albums/j8...rch2008017.jpg
adding the sleeves
http://i78.photobucket.com/albums/j8...rch2008027.jpg
welded in a new peace, then fishplated overtop.
http://i78.photobucket.com/albums/j8...rch2008031.jpg
all done!
I used 1/4" plate (alittle thick, but it was the thinest I could get from work)
First I removed the steering box,
then cut out the face of the frame, wow it was bad. I left the inside wall of the frame so it would stay strait.
the I made a template from cardboard, and fabed the peace. I put it inside the frame and welded(overhead & flat) to the old frame.
next I cut a strip of steel for the bottom (again I left the old metal there and weld to the new plate)
next I welded the sleaves for the bolts (steering box)
then I made another template to fill in where I cut the old steel (face of frame) I ground it down to fit exactly and gave it a slight bevel (for good weld penitration) Then welded it into place.
Then I fabed another plate to fishplate. this plate goes about 6-8 inches over good steel and back about 3-4 inches over my new plate.
I also welded up the crack across the top of the frame.
Then cleaned up with grinder and prime and paint.
It took me 2 full days, but I ran into MENY hard bolts....lol I couldn't even get the front wheel off, the lug nut was so stripped I tried everything, finally I used the welding machine to melt the lug nut off..lol amazing I didn't damage the aluminum rim.
Also I did all the brake , roters, and drums while I was at it.
It isn't a hard fix, I got all my supplys from work for free (steel, welding rod, grinding disks)
all it cost me was $60 for the welding machine for the weekend, and $15 for primer and paint.
Don't be affraid to do this repair, I put it off for a year, and I'm luckey the frame didn't snap, down the highway..
post #15 of 15 Old 04-24-2010, 09:37 PM
bismo183
Hello,
Just bought a 1992 Jeep, with a similar crack to what you had on the front end. Looks like you did a great job of fixing it! I noticed you're from Ontario too, have you had to get it safetied? Did they care that your frame was welded? I have a good friend who will weld it, and fabricate the part for me (also thought of buying a kit), but I am worried that if I do it, it still won't pass a safety.
I've only owned a jeep for a week, but I like this "brotherhood" already! Any advice would be greatly appreciated.
Thanks!
Bill
bismo183 is offline
How does this frame repair look? jeepxj2007 YJ Wrangler Technical Forum 2 08-23-2009 06:57 PM
TJ Frame Repair BRLK222 TJ Wrangler Technical Forum 12 06-24-2009 05:09 PM
yj frame repair elvis YJ Wrangler Technical Forum 7 09-03-2008 05:31 PM
Frame repair kbazurpe YJ Wrangler Technical Forum 13 06-12-2006 09:30 PM
Frame Repair FastX YJ Wrangler Technical Forum 3 09-04-2002 02:06 PM
