Frame Repair - JeepForum.com
post #1 of 4 Old 09-03-2002, 08:03 PM Thread Starter
FastX
Frame Repair
I have a 95 YJ. My friend made me a great spare tire carrier. When we put the new carrier on I found some weak spots on the inside of the frame rail by the rear cross member. Our thought was to cut out the old cross member, weld and fix the frame, and then weld a thicker rear cross member in. Oh I also have to fix the right rear body mount while I have the gas tank out. Anyone have the same problems??? Any ideas on the best way to fix either problem would be great.
Remember, rubber side down
FastX is offline
post #2 of 4 Old 09-03-2002, 08:19 PM
OldJeepguy
OldJeepguy's Avatar
1979 CJ7
Here is a shot of my rear crossmember during my CJ resto - it is made from 3/8" X 4" flat bar and is drilled & tapped (1/2-13) in 8 places to hold the custom bumper. Mine is welded over the existing crossmember since mine was OK but it wouldn't have been much more work to replace the old one completely.
Here is a shot with the bumper bolted on:
Steve
OldJeepguy is offline
post #3 of 4 Old 09-04-2002, 08:43 AM Thread Starter
FastX
Thanxs for the pics....Anyone else have any ideas??
FastX is offline
post #4 of 4 Old 09-04-2002, 02:06 PM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
Can you show us pictures of the rust that you see? It would help us help you a little easier ..
Is the rust surface only, or is it eaten right through?
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
Frame repair justpicaname YJ Wrangler Technical Forum 14 04-24-2010 09:37 PM
How does this frame repair look? jeepxj2007 YJ Wrangler Technical Forum 2 08-23-2009 06:57 PM
TJ Frame Repair BRLK222 TJ Wrangler Technical Forum 12 06-24-2009 05:09 PM
yj frame repair elvis YJ Wrangler Technical Forum 7 09-03-2008 05:31 PM
Frame repair kbazurpe YJ Wrangler Technical Forum 13 06-12-2006 09:30 PM
