Frame repair. - JeepForum.com
post #1 of 4 Old 04-28-2011, 07:32 AM Thread Starter
NS2110
Frame repair.
Hey guys, I have the typical frame rot on the rear of my frame right where the suspension mounts to the frame. I got an estimate to have it fixed if I supply the frame section and found this http://www.quadratec.com/products/56011_9020_07.htm however it doesn't look like a match. The frame of my Jeep appears to be a fully boxed frame but that is clearly a C channel. Is this how it's really fixed or is there some sort of other alternative replacement I'm missing?
NS2110 is offline
post #2 of 4 Old 04-28-2011, 07:40 AM
srad711
2003 WJ
That is the correct part. go to auto rust technician website and it will show you how it gets installed.
srad711 is offline
post #3 of 4 Old 04-28-2011, 09:35 AM
firefighter315
That is the correct part. Just remember they are driver/passenger side specific. You can also order directly from AutorustTechnicians, they are the ones that make that for QTec. Their website price may be slightly higher, but they will price match QTec for ya. That part sleeves the frame member since you leave the top portion of the frame when you cut out the rotted parts. You can see what it looks like installed in my build thread if you like. I used the same part in addition to replacing the fuel tank crossmember that was rotten on both ends.
My YJ Build Thread
firefighter315 is offline
post #4 of 4 Old 04-28-2011, 08:35 PM Thread Starter
NS2110
Awesome! Thanks for the fast replies!!!
NS2110 is offline
Frame repair addicted83 YJ Wrangler Technical Forum 12 09-29-2010 01:24 PM
How much frame repair is too much? fitbmxseries1 YJ Wrangler Technical Forum 2 06-24-2010 07:21 PM
Frame repair justpicaname YJ Wrangler Technical Forum 14 04-24-2010 10:37 PM
Frame Repair 95YJI6 YJ Wrangler Technical Forum 5 02-16-2010 08:39 PM
Frame Repair FastX YJ Wrangler Technical Forum 3 09-04-2002 03:06 PM
