Frame Paint - Page 2 - JeepForum.com
post #16 of 30 Old 05-26-2013, 05:44 PM
skizriz
1978 CJ7
Originally Posted by NHfireYJ View Post
On an added note consider this for the inside..
http://www.eastwood.com/internal-fra...ay-nozzle.html
If you call them and ask, they will often give it to you for $9.99 a can.
Clean the nozzle and tube out with carb cleaner when finished. You can then use it to spray a few coats of paint inside also.
skizriz is offline
post #17 of 30 Old 05-31-2013, 09:30 PM Thread Starter
devoX13
For those of you who used chassis saver, how much did you use to roll it on the frame?
devoX13 is offline
post #18 of 30 Old 05-31-2013, 09:38 PM
jamnjeep
Did my entire frame plus tranny skid and gas tank skid with a quart and had some left
1994 YJ under construction....
jamnjeep is offline
post #19 of 30 Old 05-31-2013, 09:40 PM Thread Starter
devoX13
I'm doing the bottom of my tub and fenders in it too. Was there enough left over for that? Or should I just buy and extra quart?
devoX13 is offline
post #20 of 30 Old 05-31-2013, 10:28 PM
jamnjeep
No I think you would need another quart.
jamnjeep is offline
post #21 of 30 Old 06-02-2013, 09:58 PM Thread Starter
devoX13
Thanks for the input!
devoX13 is offline
post #22 of 30 Old 06-03-2013, 06:37 AM
Que89YJ
Hey JamonJeep did you do both sides of the skid when you painted? What did you do to prep for the paint? I am ready to pull my tub and go to a Fiberglass tub and I am trying to get a good idea of what I need to do to get the frame and plates painted.
Que89YJ is offline
post #23 of 30 Old 06-03-2013, 10:45 AM
jamnjeep
I did paint both sides of my tranny and gas skids. Everything was in great shape, just light surface rust in a few spots. I just hit those spots with a wire brush then cleaned everything with soap and water. Once dry slapped on the paint with a 4" brush. Turned out great and I'm happy with it.
jamnjeep is offline
post #24 of 30 Old 06-03-2013, 01:22 PM
Jims-87YJ
1987 YJ Wrangler
Devox13, sorry I am late to the party but I did my frame and skid (sandblasted first) with Chassis Saver and a cheap sponge brush. Also used the Eastwood internal Frame coating that also worked great. I did coat the Chassis Saver with the Eastwood Extreme Chassis Black (as the Chassis saver is not UV stable) Jeep has been back on the road since Oct and I am still very pleased with the outcome. see my build thread for pictures.
1987 YJ, 258, Weber 32/36, HEI, Custom Sound bar, Hardtop/Sun-rider/bikini tops, 2" Lift, 1/2" Boomerangs, 1" Body & MM Lift. 32x11.5x15 Copper STT's on Black Rock 950 Lobos w/4" backspacing, Still need Front Bumper and Seats.
My build thread:
Jims-87YJ is offline
post #25 of 30 Old 06-04-2013, 05:18 PM Thread Starter
devoX13
Did anyone reduce the chassis saver before rolling or brushing it on? And what rollers or brushes did you use?
devoX13 is offline
post #26 of 30 Old 06-04-2013, 06:55 PM
XJ93
There is no need to reduce the Chassis Saver if you are rolling or brushing. The reducer is only needed for spraying.
XJ93 is offline
post #27 of 30 Old 06-04-2013, 07:09 PM Thread Starter
devoX13
But should I reduce it if I have any left over?
devoX13 is offline
post #28 of 30 Old 06-04-2013, 07:39 PM
XJ93
No, all you will do is shorten it's shelf life. Any left over Chassis Saver can be kept in the can, provided you place plastic wrap over the top before putting the lid on. The ONLY reason to reduce it is to spray it. Once you add reducer anything left over will have to be thrown out.
XJ93 is offline
post #29 of 30 Old 06-04-2013, 08:45 PM
Jims-87YJ
1987 YJ Wrangler
I had very good results with the inexpensive foam brushes from Lowe's (buy a couple different sizes and toss as soon as it starts falling apart). It covers well and self levels as it dries. I have had good luck with plastic wrap between can and lid, seal tight and reuse the clips to hold the lid in place, and then store it in the refrigerator (or a cool place).
My build thread:
post #30 of 30 Old 06-04-2013, 09:04 PM Thread Starter
devoX13
Thanks guys!
devoX13 is offline
