Frame Paint - JeepForum.com
post #1 of 30 Old 05-24-2013, 01:11 PM Thread Starter
devoX13
Frame Paint
I'm planning on using chassis saver to paint my frame and the bottom of my tub. Should I spay it or roll/brush it on?
Or are there better alternatives to chassis saver?
Any input would be appreciated.
devoX13 is offline
post #2 of 30 Old 05-24-2013, 04:08 PM
95YamJam
I have had super good luck with duplicolor spray on bedliner. It's pretty cheap and easy to spray. Tough as nails once it cures.
My build: http://www.jeepforum.com/forum/f22/95-yam-project-1527472/?highlight=
95YamJam is offline
post #3 of 30 Old 05-24-2013, 04:18 PM
NHfireLJ
NHfireLJ's Avatar
On an added note consider this for the inside..
http://www.eastwood.com/internal-fra...ay-nozzle.html
SOLD
YJOTM FEB 2013
NHfireLJ is online now
post #4 of 30 Old 05-24-2013, 04:19 PM
PA_YJ19
I just used a paint brush with my chassis savor, itll even itself out as it dries. Spraying on is nice if u have the room and tools, I just didn't have the room to do it.
PA_YJ19 is offline
post #5 of 30 Old 05-24-2013, 08:37 PM Thread Starter
devoX13
I'm not sure what I'm doing yet. Spaying would be more convenient, but rolling/brushing would be a tad less messy..
devoX13 is offline
post #6 of 30 Old 05-24-2013, 09:13 PM
JohndKc
1987 YJ Wrangler
I just bought a gallon of Chassis saver and S8 reducer. I intend to spray it, but am on the fence. If Chassis saver is anything like POR 15, it has a Midas touch, but instead of turning everything to gold it turns everything black forever. I worry that it will destroy my paint gun. I have been tossing the idea up of buying a cheap spray gun just for this job.
33rd BCT
Alpha 2/122 FA
68W
JohndKc is offline
post #7 of 30 Old 05-24-2013, 10:13 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
X2 that's what I used on my Xj's bumpers , Sliders, skids, undercarriage. And on my YJ's frame , tcase skid, crossmember , hitch ......
Sent from iPhoneusing JeepForum
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #8 of 30 Old 05-24-2013, 11:31 PM
Shadownwpa
Anyone here get their frame galvanized (hot dipped)? I wish I'd have thought to do so before putting the two coats of por15 and a coat of tractor paint on. On topic I used a brush, tried a roller but it's really not much better and you still need the brush for all the corners and brackets anyways.
Shadownwpa is offline
post #9 of 30 Old 05-25-2013, 06:59 AM
PA_YJ19
95 yjs came galvanized, frame and body. If u have the money to do all that then get it powder coated. Powder coat will last much longer than galvanizing does from my experience.
PA_YJ19 is offline
post #10 of 30 Old 05-25-2013, 08:08 AM
95YamJam
It's also great if you do happen to chip it off. Just scuff and hit the spot. Half my jeep is done in that stuff.
95YamJam is offline
post #11 of 30 Old 05-25-2013, 08:56 AM
crackedcornish
this is the exact reason I did my entire Jeep in the stuff...of course I painted over the exterior of the tub in rustoleum safety orange as well...just to be a bit more colorful
Orange Jeep Club #88
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
crackedcornish is offline
post #12 of 30 Old 05-25-2013, 09:36 AM
XJ93
I sell a lot of Chassis Saver, the local school bus mechanics love it. It won't damage a paint gun if you clean your gun properly per the instructions right away. If you brush it on you won't need to buy the reducer at all, but make sure you put some plastic wrap over the top of the can before you put the lid on if you have any left otherwise it will basically seal itself and you won't get that lid off. Also you will need to topcoat the stuff if it is anywhere the sun will hit it. The sun doesn't decrease the strength or quality but will fade it to a grayish color.
XJ93 is offline
post #13 of 30 Old 05-25-2013, 11:23 PM Thread Starter
devoX13
Thanks for the info! Would you recommend spaying or brushing it on? It'll be on the frame and underbody so no sun hppefully haha
devoX13 is offline
post #14 of 30 Old 05-25-2013, 11:54 PM
XJ93
Personally I would brush it on. Even though it is a bit more time consuming it's less mess, you won't have to buy the reducer, and you can be sure you hit everything with a good coat. If you are doing the frame and underbody brush would really be better anyway.
XJ93 is offline
post #15 of 30 Old 05-26-2013, 06:25 PM
superj
I Just did rustoleum on the back and tailgate. Super easy to do, worst part was roughing up the paint.
I don't feel like working on anything at this time so i sold my yj.
superj is offline
