frame info - JeepForum.com
post #1 of 3 Old 07-18-2011, 11:46 AM Thread Starter
Hillbilly Jeep
frame info
hello all... i have a 90 with a 4.2....been lookin for frames and i think i found a good one.. one thing is thats its a 4cylinder. how much will have to do to get it to fit my 6cylinder? the frame is off a 94... gonna go look at it in a few days so just seein what i would have to do to get it to work
thanks Jeremy
ps its 500$?
and how can i check to see if its a bent frame?
Hillbilly Jeep is offline
post #2 of 3 Old 07-18-2011, 03:20 PM
Alfons
You should only need to reposition the motor mount posts - measure where they are on yours and put them in the same place.
Normally a bent frame is fairly easy to spot when there's nothing on the frame to hide it. A quick check is to look for cross members being square and then look back to front for any sign of twist. Finally, do a diagonal measurement - from the left rear corner to the front right corner & then this measurement should be the same as a measurement on the other diagonal - right rear to left front. For precise measurements on everything except the motor mount posts, do a search on this site or even on the internet for a YJ frame diagram, there are lots of them out there (many of them show the measurements in millimeters).
$500 is good for a solid frame that has never needed repair.
Alfons is offline
post #3 of 3 Old 07-22-2011, 11:37 PM Thread Starter
Hillbilly Jeep
update... well i ended up buying it... it looks real good..but i havent payed for it yet due to the guys still has to take the motor and tube outta it since hes parting the rest..hopefully he calles me within the next week and says its ready for pick up... just one more ? how does one clean out and seal the inside of the frame? since this one is solid i dont want this happenin again
thanks
Jeremy
Its a sad day...looking for frame info skimsurf YJ Wrangler Technical Forum 12 01-31-2011 08:28 PM
Tj frame info chachalaca TJ Wrangler Technical Forum 7 12-20-2010 11:37 AM
YJ Frame differences? Can I frame swap any platform Nate M YJ Wrangler Technical Forum 5 10-26-2010 09:17 AM
bestop frame better than stock soft top frame? goose142004 YJ Wrangler Technical Forum 10 11-24-2009 12:34 PM
Factory Warranty info? Top info? BlueRidgeRunner TJ Wrangler Technical Forum 5 06-27-2004 03:52 PM
