frame fix. new rear section, or weld on new plates? - Page 2 - JeepForum.com
post #16 of 19 Old 03-12-2010, 10:49 AM
ovrlnd
Quadratec now sells replacement sections at a great price.
Jeep Frames & Accessories - Quadratec
"We'll get out of this disaster in time for the next one"
"I'm done recomboobulating the energy-mo-tron"
88 YJ, 350/350 Chevy, Twin Stick Dana 300 with JB 32 spline rear output, 6.5" lift, Front Scout II Dana 44 w/Yukon 4340 shafts, trac loc, 4.27's, Warn Premium Hubs, flipped YJ Tie Rod, Ford F150 front calipers, Rear Scout II Dana 44 w/Alloy 4340 shafts, HD RPT retainer plates, 4.27's True trac, Steeltech Disc brakes, Cage upgrade, B&M Prostick Shifter, Custom Fabbed tire, gas, jack carrier, 3/8 angle rear bumper, clevis's all around, old & reliable rep8000 winch. Flood lights. loud stereo. 35x12.50 swampers and a bunch of other stuff
ovrlnd is offline
post #17 of 19 Old 03-12-2010, 11:04 AM
NHfireLJ
NHfireLJ's Avatar
Originally Posted by headstrong50 View Post
are you happy with the rear frame repair kit you did? should i go that route?
VERY!!!! USE the ART, takes some light fabbing to get everything together...A body / weldding shop can do it, if you are not a welder...
I knew I was going to add a rear rock bumber so instead of the MORE brace, I used the bumber as my rear cross member...works great
NHfireLJ is offline
post #18 of 19 Old 03-12-2010, 11:09 AM
monkeyhouse
anybody using these?
Daystar KJ09120BK - Daystar Front Extended Bump Stops in Black for 87-95 Jeep® Wrangler YJ - Quadratec
Was just curious if they were an improvement?
First Jeep was an 1989 YJ, I've also had a Grand Cherokee. Currently, I have a 99 XJ.
monkeyhouse is offline
post #19 of 19 Old 03-12-2010, 11:59 AM
NHfireLJ
NHfireLJ's Avatar
Originally Posted by monkeyhouse View Post
Yes and yes!
NHfireLJ is offline
Do winch plates replace plastic "Jeep" frame cover? ZeroGravity YJ Wrangler Technical Forum 3 02-05-2010 11:29 AM
Should i weld clevis tabs to the frame haymaker4life TJ Wrangler Technical Forum 14 01-06-2009 07:46 PM
Weld Nuts in Frame Busted? CherokeeGuy1998 TJ Wrangler Technical Forum 6 11-03-2008 07:02 PM
wont to weld the rear end yjjeep92 YJ Wrangler Technical Forum 12 04-21-2006 08:07 AM
Frame section repair. (part found) OlllllllO Jeep1 YJ Wrangler Technical Forum 11 03-05-2006 04:54 PM
