frame fix. new rear section, or weld on new plates? - JeepForum.com
post #1 of 19 Old 03-11-2010, 08:50 PM Thread Starter
headstrong50
i have very very bad rear frame rust in my 93 YJ. should i weld on plates over the existing damage, or buy a new rear section and have it welded on?
going off road is like being married, its great until you bang something you shouldnt.
headstrong50 is offline
post #2 of 19 Old 03-11-2010, 09:16 PM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
I'm not saying this is your only choice, but I welded some angle iron back there.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline
post #3 of 19 Old 03-11-2010, 09:27 PM
Burnerman
Burnerman's Avatar
How bad is it? This bad?
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #4 of 19 Old 03-11-2010, 09:28 PM Thread Starter
headstrong50
idk if that would work for my situation. there are holes all along the leaf spring mount area.
post #5 of 19 Old 03-11-2010, 09:29 PM Thread Starter
headstrong50
ohh....my....jeep god.....no, mine is not that bad, actually, mine looks new compared to that..
post #6 of 19 Old 03-12-2010, 05:25 AM
Burnerman
Burnerman's Avatar
Post a pic or link to a pic of your frame. many on the forum have repaired sections of frame. Make sure you get in there and bang on the frame with a hammer. Knock all the rust off the frame and make sure you know how bad the rust is before you start.
96 ZJ.
post #7 of 19 Old 03-12-2010, 06:52 AM
DaveinHouston
Being as you obviously have the tub off the frame I'd be looking for another frame. If you have rust that bad in that location it's going to be bad elsewhere. You'll spend more time and money trying to patch that than it would cost you to scrounge another frame and swap it.
- 2003 Rubicon - 4" Lift, 35" KM2s, 5.13 gears, winch
- 1968 CJ5 - Dauntless V6, T-86, Dana 18, D27 & D44
- NRA Life Member - Licensed to Carry and Do.
DaveinHouston is offline
post #8 of 19 Old 03-12-2010, 10:02 AM Thread Starter
headstrong50
i cant afford an all new frame. i can have my brother do all the welding for me at his shop for free. all i need to do is the prep. i know its possible to do. just not sure how to go about it.
post #9 of 19 Old 03-12-2010, 10:19 AM
DaveinHouston
If you've got a free shop and welding there's no limit to what you can do. I'd beat around on the rest of that frame and see if you have any other rot while you're at it. If you could find a good frame at the wrecking yard you could cut off the pieces you need.
post #10 of 19 Old 03-12-2010, 10:23 AM
NHfireLJ
NHfireLJ's Avatar
Auto Rust technologies...for frame and shackle mounts.
Highly recommended!!!!
MORE sells the rear cross member
I used a Smitty rear bumber as my cross member..
Picture 146a.JPG   Picture 150a.JPG   Picture 181a.jpg   Picture 147a.JPG   Picture 174a.JPG
NHfireLJ is offline
post #11 of 19 Old 03-12-2010, 10:28 AM
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
http://www.jeepforum.com/forum/f12/f...epair+underway
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline
post #12 of 19 Old 03-12-2010, 10:30 AM Thread Starter
headstrong50
okay. but do i need this
http://www.jeepforum.com/forum/f130/...er-cut-915669/
or this
ART-42L - Autorust Driver Side Rear Shackle Mount Section for 87-95 Jeep® Wrangler YJ - Quadratec
post #13 of 19 Old 03-12-2010, 10:34 AM
Tshark299
Tshark299's Avatar
1987 YJ Wrangler
I had the same problem:
I got lucky and another member on here had a cut up but rust free YJ frame available. He cut about 2 feet off the rear of his driver's side frame rail and mailed it to me. Ended up being cheaper for me than the Auto Rust Tech panel, but I've heard good things about the quality of their parts.
- 4.0L, AX-15, NP231, 4.10s: 3.5" BDS, 31" Muds
- Donated drive train to the YJ, Parted out the rest
- Buick 225 V6: Painless Wiring Harness, Warn Overdrive & Hubs, 2" Lift, 31" Muds
Tshark299 is offline
post #14 of 19 Old 03-12-2010, 10:38 AM Thread Starter
headstrong50
are yo happy with that frame repair kit you welded on the rear to patch the holes? is that the route i should go?
post #15 of 19 Old 03-12-2010, 10:39 AM Thread Starter
headstrong50
are you happy with the rear frame repair kit you did? should i go that route?
Do winch plates replace plastic "Jeep" frame cover? ZeroGravity YJ Wrangler Technical Forum 3 02-05-2010 11:29 AM
Should i weld clevis tabs to the frame haymaker4life TJ Wrangler Technical Forum 14 01-06-2009 07:46 PM
Weld Nuts in Frame Busted? CherokeeGuy1998 TJ Wrangler Technical Forum 6 11-03-2008 07:02 PM
wont to weld the rear end yjjeep92 YJ Wrangler Technical Forum 12 04-21-2006 08:07 AM
Frame section repair. (part found) OlllllllO Jeep1 YJ Wrangler Technical Forum 11 03-05-2006 04:54 PM
