Four wheel low range wont work - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Four wheel low range wont work
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! USA Standard Chromoly Front Axle Shaft Kits with Dana 30 4The Jeep Forum Discount is ON!
Unread Yesterday, 04:28 PM   #1
grayrf
Junior Member
Boy is back from Cali, should have checked for this sooner.
Just put in a 4 inch Rubicon lift kit and bigger tires, had some shifting problems, but thanks to this forum that is resolved.
The jeep will not shift into 4 wheel low range, I am sure it has everything to do with the lift kit, I never checked to see if it worked after the install.
What is the fix or solution to getting it to shift into 4 wheel low?
V/R
grayrf is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 05:03 PM   #2
Drednot
Drednot's Avatar
If you stick your head up in there, you should be able to see the shift linkage and the adjusting block. Just slide the block till you get it to pop in 4LO
91 YJ Sahara, 4.0L, AX-15/NP231, D30/D35
12 Cherokee 4x4,3.7L,
"Non Vi Sed, Arte"
Drednot is online now   Reply With Quote Quick reply to this message
Unread Yesterday, 05:46 PM   #3
RockWoRM
RockWoRM's Avatar
Also check the linkage bushing... they can wear out and cause binding.
'92 YJ, 4.0, 5sp, 8.8 w/ 4.56's locked F&R, Teralow 4-1, HD SYE, BDS 5" SUA lifted on 35 MTR's. PSE front trail cage kit, 1ton TRE flip, 1"shackles, 1"BL, 1" MM. <><
Originally Posted by 80 CHOPPER View Post
Knowledge is a tool, without knowledge, you are just a tool.
RockWoRM is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 06:22 PM   #4
216yj
This is way off topic but Dred or anyone else what models had those heater vents seen in you 3rd pic?? Did it come with the oem air conditioning setup or is it only for certain models?
mine looks like this http://www.google.com/imgres?imgurl=...FcVXPgodYo0AIg (not my jeep way to clean) but it looks similar
i would love to add this if its possible.
216yj is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 06:24 PM   #5
jbolty
jbolty's Avatar
that's from factory a/c, mounts under the dash
as for the linkage, easy adjustment and that's almost certainly the trouble but unless you did a body lift should not have been affected.
If you live within wheeling distance of San Diego county, click here
jbolty is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 06:30 PM   #6
Reno72
TC drop has caused some people problems.
"Says the guy driving the plastic Barbie Jeep". JLH
Reno72 is online now   Reply With Quote Quick reply to this message
Unread Yesterday, 09:22 PM   #7
Drednot
Drednot's Avatar
Originally Posted by 216yj View Post
This is way off topic but Dred or anyone else what models had those heater vents seen in you 3rd pic?? Did it come with the oem air conditioning setup or is it only for certain models?.
Yeah, its the factory air. Up until the TJ came out, A/C was an add on kit that hangs under the dash in a stand alone system. You can still buy a complete system new from the manufacturer.
http://jeepair.com/wrangler-ac-kits.html
"Non Vi Sed, Arte"
