found two connectors behind dash what are they - JeepForum.com
post #1 of 13 Old 06-01-2010, 08:25 AM Thread Starter
bword
one is like a small light bulb connector and the other is like a spring loaded switch I am clueless on what they could be
bword is offline
post #2 of 13 Old 06-01-2010, 08:33 AM
Burnerman
Burnerman's Avatar
The switch is for the fan on & off when you move the heat control lever. The fan is off in the off and vent positions. The light socket is for the heater control lamp.
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #3 of 13 Old 06-01-2010, 08:34 AM
superlack
courtesy light and the pertaining door switch?
edit: scratch that. beat.
But.... Heater control lamp?
superlack is offline
post #4 of 13 Old 06-01-2010, 08:48 AM Thread Starter
bword
oh damn..gotta find that bulb number and where to mount back that switch th
bword is offline
post #5 of 13 Old 06-01-2010, 09:00 AM
Burnerman
Burnerman's Avatar
It's a 194 bulb. If you remove the plastic trim piece from around the heater control and radio, you'll see the 4 screws that hold the heater controls in. The controls will pull out enough to get to the bulb. The cables will keep it from coming out very far. You can remove the cable clamp above the gas pedal to get a little more slack. When you start to pull it out be careful of the 2 vacuum hoses on the left side of the controls. They operate the cowl air damper.
96 ZJ.
post #6 of 13 Old 06-01-2010, 09:01 AM
Burnerman
Burnerman's Avatar
If that harness won't reach it could be for the rear defroster or wiper option. Do you have a better pic?
96 ZJ.
post #7 of 13 Old 06-01-2010, 09:14 AM Thread Starter
bword
no i dont but i could take one later on
bword is offline
post #8 of 13 Old 06-01-2010, 09:36 AM
muddy93
1987 FSJ Wagoneer
The black plug is for a light bulb, I think it's supposed to go into a holder on the back side of the dash, and is to light up the area where the rear wiper/defrost switches go.
The white switch thing is supposed to be mounted to the heater controls. it's a vacuum switch, and controls the driver side vent door that is located in the cowl vent. It closes the vent door when the heater is switched to the "off" position.
maroon 1987 Grand Wagoneer. stock for now...
muddy93 is offline
post #9 of 13 Old 06-01-2010, 02:28 PM Thread Starter
bword
you guys were right about the heater door switch I messed with it I head it switch. I just need to figure out how to mount it back in its rightful place
bword is offline
post #10 of 13 Old 06-01-2010, 02:40 PM
muddy93
1987 FSJ Wagoneer
If I remember correctly, it mounts to the top of the heater controls, with two screws. it sits so that when the heat is switched off, the arm presses the little plunger on the switch.
muddy93 is offline
post #11 of 13 Old 06-09-2010, 04:17 PM Thread Starter
bword
Do u have a pic of it by any chance?
Selling a Totaled XJ in Ct..PM me for details
bword is offline
post #12 of 13 Old 06-10-2010, 06:26 AM
muddy93
1987 FSJ Wagoneer
I found a pic suing google image search, but I'm not sure if it will show up.
well, at least the pic showed up, sorry it's so small. Anyway, the pic is looking down on the top of the heater controls(with them removed from the dash). You can see the switch towards the top, on the left side. If I remember correctly, the screws come in from the bottom, and the nuts were on top of the little ears that are on the switch.
muddy93 is offline
post #13 of 13 Old 06-10-2010, 08:16 AM Thread Starter
bword
thanks man ill be crawling under there this weekend to try to put this puzzle back together lol
bword is offline
'00 TJ engine connectors won't come apart... VetteMemphis TJ Wrangler Technical Forum 0 03-10-2009 08:09 AM
Shot in the dark - Found an oddball light under my dash, any ideas where it goes? Tobey YJ Wrangler Technical Forum 13 08-04-2008 09:02 PM
Open Connectors under dash jdroller TJ Wrangler Technical Forum 2 02-17-2008 10:42 PM
What's this cable I found under my dash trim? Passenger side. TheMightyGoat TJ Wrangler Technical Forum 4 08-30-2007 11:19 PM
Where do these connectors go? odanny TJ Wrangler Technical Forum 3 10-23-2005 08:27 PM
